Heater issue after wire fix.
Old Feb 13, 2012 | 07:03 PM
smgdata's Avatar
Default Heater issue after wire fix.
So i had the wonderful heater prob that seems to happen on these cars. drivers side heater always on etc..
anyways i replaced the Dual heater valve, took the dash apart put the little wire on the burned board. and all was well. flash forward to this week and the things work but outa the blue and at random moments the passenger side heat is stuck on.
ANy ideas?
Old Feb 13, 2012 | 07:35 PM
Gus's Avatar
Gus
I think you are in the wrong area. Do you have a S-Type or a XJS? You posted in the S-Type
Old Feb 13, 2012 | 08:00 PM
smgdata's Avatar
I wouldn't have posted this In the S-type area if the question wasn't about a S-type.
its a 05.
Old Feb 13, 2012 | 08:03 PM
Gus's Avatar
Gus
Good to know! I hope you get help.
its a 05.
Old Feb 13, 2012 | 09:25 PM
Amadauss's Avatar
its a 05.
I think the thought of wrong place is because you do not have the S type car listed under your screen name, but other jag models.
Old Feb 13, 2012 | 09:31 PM
smgdata's Avatar
I know i know it would be my mothers.
anyways that all aside. its bothering me what issue is
Old Feb 14, 2012 | 08:21 AM
JagV8's Avatar
You could start by looking at the volts on each side of the valve as you change each side's setting from cold to hot. If the volts move properly then I suppose it's a faulty valve and if they don't then the CCM looks suspect.
Old Feb 14, 2012 | 08:37 AM
Gus's Avatar
Gus
You said that you replaced the DCCV, my procedure is geared towards its replacement and your car is different MY but a little information might help. I have a link to jaguar climate http://jagrepair.com/DCCVSType.htm that has a trouble shooting procedure that should help. I also have wiring diagrams if you do not have one for your car.
Old Feb 14, 2012 | 12:04 PM
smgdata's Avatar
Thanks for the info. im hoping that its not the valve that was a pain to replace.
the wiring diagram might be helpful.
Old Feb 14, 2012 | 05:05 PM
Gus's Avatar
Gus
Sorry I thought I had it for a 2005 but only to 2004 http://jagrepair.com/images/AutoRepa...x2062004en.pdf I hope it helps.
Old Feb 14, 2012 | 08:51 PM
Brutal's Avatar
there a 2 circuits. If you repair the drivers circuit, dont you think that MAYBE the pass circuit blew now too. it happens to both sides and not always both at the same time
Old Feb 15, 2012 | 03:51 AM
smgdata's Avatar
i was thinking that but, wouldnt the passenger circuit blow only if the valve died? i hope not !!
when i looked at the board i dont see any burned marks, ill check out the wiring diagram
and try to see if i can find the circuit.
Old Feb 15, 2012 | 06:18 AM
JOsworth's Avatar
Yea, that would make sense. Remember that sometimes the circuits in the CCM don't go along with the DCCV. When I had my 05 it took months for the CCM to act up after a DCCV replacement, and even then it still worked just made the display flash. Mine was warranty so I never did break it open. The dealer just replaced it.
I would look at the CCM for the passenger circuit and put a wire patch on that as well and see if your issue doesn't clear up.
Forcedair1
Sep 8, 2025 01:57 PM
jagent
Sep 12, 2015 01:40 AM
Bones
Sep 8, 2015 08:34 PM
philwarner
Sep 5, 2015 10:05 AM
XKR-NC
Sep 4, 2015 08:23 AM
