Help again with my 2000 jaguar s type v8
Old Sep 22, 2020 | 01:51 PM
Ralph Majarais's Avatar
Default Help again with my 2000 jaguar s type v8
So i got the coolant tank replaced and its good doesnt overheat ,but now engine light is on.one mechanic says software update is all it needs but thats like4- 500 all together at the dealership. And another says timing belt.but it checked out fine and another mechanic says just needs the engine clean. So i am so lost
Old Sep 22, 2020 | 09:10 PM
motorcarman's Avatar
I assume you are referring to the Recall/Service Action S303-S145 for the faulty coolant level sender delete.
I performed several dozen 'disable the coolant level sensor' ECM configurations when I worked at the dealer.
Here is the info you need if this is your issue.
Old Sep 22, 2020 | 09:34 PM
kr98664's Avatar
Originally Posted by Ralph Majarais
but now engine light is on...
Are you talking about the little check engine light on the dash? If that is illuminated, some corresponding fault codes will be stored.
Please have the codes read with a scanner or code reader, and post them here. Please post the 5 digit code(s) such as P0301, not the definition the reader may display. Some codes are Jaguar-specific and the generic definitions are are not always accurate.
I am surprised three different mechanics are giving you three wildly different ideas. Sounds like none of them even bothered reading the codes, or are ignoring them and suggesting unneeded expensive repairs.
Old Sep 22, 2020 | 11:45 PM
Default Thank you
Old Sep 23, 2020 | 06:25 AM
kr98664's Avatar
Your picture is hard to read, but does that say P1388? If so, that’s a fairly common fault, often with P1383 for the other bank. No need to panic, it often clears up with a fresh oil change.
Everything you ever wanted to know here:
https://www.jaguarforums.com/forum/s...errors-234131/
https://www.jaguarforums.com/forum/s...bad-vvt-68687/
Old Sep 23, 2020 | 09:19 AM
well im happy now, thank you very much
Old Oct 3, 2020 | 07:24 AM
davidladewig's Avatar
I replaced this tank THREE times the first 3 months I had my s-type. Two of the replacements cracked. Just bad luck but I never had any warning lights. That reservoir is a bear to change.
Old Oct 3, 2020 | 12:15 PM
S-Type Owner's Avatar
Aftermarket tanks...? Uro brand, perhaps?
Old Oct 3, 2020 | 05:12 PM
Why don't you disconnect the battery, touch the + and minus - together, then wait about 30 minutes and hook up the pos. first and neg second and the computer will reset. Be sure you have your remote in hand. When you open the door to put the key in, the HORN will go off. Use your remote to shut it off. Start it up and it should reset.
Old Oct 3, 2020 | 05:15 PM
The good one came from Brand Parts in California. The other 2 were covered under warranty.
PetJag
Feb 19, 2020 09:10 PM
Camnelson324
Mar 31, 2014 05:40 PM
domey
Feb 1, 2013 06:51 AM
fisterbottom
Aug 6, 2010 03:00 AM
TURBOPOWERED68
Dec 21, 2008 02:51 PM
