help with engine
Old May 21, 2015 | 09:52 PM
sharito143's Avatar
Default help with engine
My hubby is working on a 2000 jaguar s type 3.0 he swapped out the engine for one of the same and the new engine is making a weird clanking noise and has really no power but it runs...any suggestions? Also does any cheaper engine fit in it
Old May 22, 2015 | 06:25 AM
Welcome to the forum sharito143, I've moved your post to it's own thread.
Don't forget your intro in the new members area.
Any clues where the noise is coming from?
Another type of engine is not really an option.
Old May 22, 2015 | 08:20 AM
pab's Avatar
pab
>any suggestions?
Any engine codes?
Jaguar - it's not an automobile, it's a Motorcar
'08 Jaguar S-Type 4.2 "Satin Edition" (250.06 hp / 259.67 torque)
Old May 22, 2015 | 08:27 AM
sharito143's Avatar
Its the engine that's making the knocking noise. We got it at junkyard and it came with no warranty so now we are thinking its defective any suggestions
Old May 22, 2015 | 09:14 AM
Mikey's Avatar
There's a hundred things that can cause an engine to knock, virtually none of which are exclusive to Jags. I think you might be looking at removing and returning the junkyard engine.
Old May 22, 2015 | 09:26 AM
Is it a loud scary knocking noise or just an annoying knock, does it come from the top, bottom, front or back of the engine?
Old May 22, 2015 | 01:01 PM
davideliarosenbloom's Avatar
Default engine swap
There isnt anything cheaper than a jag 3.0 engine, used they are less than $500 but Id recommend paying an extra $500 and getting a nice low mileage one (< 75000), these are pretty bulletproof engines so once you have a good one and 99.99% of them are good, you should be fine if you take care of it,.
D.K
Dec 10, 2023 02:05 AM
cissdm
May 3, 2016 06:02 AM
OkieTim
Sep 8, 2015 04:48 PM
MrMellor
Sep 7, 2015 10:22 AM
OkieTim
Sep 2, 2015 12:48 PM
