help engine code P0353
Old May 29, 2008 | 06:07 PM
FactoryJaguarTech's Avatar
Default RE: help engine code P0353
Is it a left hand drive car?
Passenger side doesnt help...
Old May 29, 2008 | 07:00 PM
jag_genius's Avatar
check the harness behind the intake close to fiewall. that runs near the back of the intake.. it goes thru a black circular bracket that shares the back 2 bolts of the intake.. the harness chaffs on the bracket and shorts out some coils.. throw the bracket away...
Old May 30, 2008 | 05:05 AM
Di you remove the bracket like Genius said?
If you didnt, do so and do not reinstall. Make sure you put the two bolts back into intake. Do not use bracket.
You must have had intake off already to change coil?
Just for ***** and giggles, on drivers side, swap the first two coils with each other and see if code changes.
I have seen false flagged codes for cyl numbers when using generic scan tool.
First though lose the bracket.
Old May 31, 2008 | 01:35 PM
We are not talking about the plastic piece. There is a big round metal bracket at rear of engine. Remove that and look for wire chaffing.
Are you sure the coil just got broken? Possible was broken when you installed and that is why code not changing?
Swap the other side coils around too. See if code changes.
This problem should not be hard to find if giving hard code constantly.
Old Jun 2, 2008 | 05:11 AM
Use dvom and see if the coil is getting power. If I remember correctly, coils should have 12 volts and the PCM should ground it to make coil fire.
I have seen bad PCM, but it took out whole bank of coils.
You may need a coil tester, or take it somewhere to have it diagnosed correctly.
The bracket would have been obvious if there. Someone likely already tossed it.
Old Jun 3, 2008 | 05:02 AM
Only thing I can suggest now is get it diagnosed professionally.
If your car is less than 8 years old and under 80k miles, the PCM is covered by emissions warranty, if that is problem.
toronadomike
Jan 22, 2026 10:13 PM
philwarner
Oct 4, 2024 01:37 PM
Jpav27
Jul 31, 2022 06:43 AM
cissdm
May 3, 2016 06:02 AM
OkieTim
Sep 2, 2015 12:48 PM
