Help I have a running fault
Old Oct 19, 2012 | 07:06 AM
lovelylellops's Avatar
Unhappy Help I have a running fault
hi all i could do with some of your great advice....... i had running fault with my s-type 3.0 v6.......all coils and sparks have been renewed and manifold gaskets and engine has been flushed twice. she wouldnt run on all 6 for toffee so we had her put on comp- was saying left bank cam shaft sensor so it was replaced-it was still running badly so back to the computer-saying left bank cam shaft sensor again so it was replaced (in case the other was faulty by chance) but she still wont run on all 6. we have been told it is a timing fault so the belt needs checking but as far as i am aware its on a chain? can anyone shed some light on this please
thanksx
Old Oct 19, 2012 | 08:41 AM
JagV8's Avatar
Sounds like a garage that swaps parts instead of doing proper diagnosis - very expensive
I'd go elsewhere.
What actual (OBD) code number(s) do you have?
Old Oct 19, 2012 | 09:10 AM
steveinfrance's Avatar
Buy yourself a cheapo OBD code reader so you can post the codes here as JagV8 says.
Old Oct 19, 2012 | 12:53 PM
tbird6's Avatar
Search for the problem on this forum. It has been discussed and Brutal has posted some things to try. Seems like some cleaner in the oil helps and changing what weight oil you use might help too.
Old Oct 19, 2012 | 02:21 PM
Jagtastic's Avatar
My 2001 3.0 wouldn't run right, ate some coils, and kept telling me cam sensor. Turned out to be chaffed wires by the fuel connection (top rear of the engine). The short to ground must have been confusing the computer.
Old Oct 19, 2012 | 05:37 PM
JagV8's Avatar
Good point! You're not the only one - I've seen a few. Well worth checking.
Old May 8, 2013 | 02:45 PM
hi and thanks for all your help-turns out it was a faulty set of coils!!! shes running like a dream now but the steering lock wont come on-jag tech said its the steering column locking module.....anyone know how to change it :S ?
thanks in advance
trosty
26
Dec 18, 2022 06:40 PM
cissdm
May 3, 2016 06:02 AM
joesoap
Sep 10, 2015 01:09 AM
Doovoe
Sep 8, 2015 05:42 PM
