help I'm going backwards
Old Jun 15, 2013 | 12:15 PM
richblackman21's Avatar
Exclamation help I'm going backwards
I recently tried to start my 2003 jaguar s type and it wont turn over. I got lights and wipers and radio but nothing else, I replaced the battery and after several attempts it started once. I then messed up and tried to start it in neutral, now its stuck in reverse,the key is stuck in the ignition, and I'm jus stuck. any help would be greatly appreciated.
Old Jun 15, 2013 | 02:00 PM
JagV8's Avatar
Is it really stuck in reverse? With key in (probably need position II) and foot on brake (if needed) you should be able to select any gear position.
Old Jun 15, 2013 | 02:36 PM
Bad Cattitude's Avatar
Check the shifter linkage @ the transmission.
Old Jun 15, 2013 | 02:51 PM
JagV8's Avatar
Good point - if it won't shift as I described then likely a problem with the 2 bolts which should be on the side of the trans.
Old Jun 16, 2013 | 12:18 PM
thanks so much jag v8 and cat man do without your help i never would of been able to fix it. I will add all my info and complete my member info. thanks again you saved me hundreds of dollars i am so grateful.
Old Jun 16, 2013 | 12:22 PM
Glad we could help!
Old Jun 16, 2013 | 12:34 PM
JagV8's Avatar
Hooray! Good to hear, thanks for the follow-up.
Dave1109971
Dec 15, 2015 06:16 PM
ebrand
E type ( XK-E )
Sep 23, 2015 11:34 AM
multijag
Sep 14, 2015 04:54 PM
diablomkii
Sep 14, 2015 02:37 PM
st.clair
Dec 3, 2011 06:40 PM
