Help My jag wont start
Old Jan 29, 2016 | 04:10 PM
edward rederer's Avatar
Default Help My jag wont start
Hi i have a 2002 jaguar stype. After i changed the battery it never ran again. It has good spark but the fuel pressure is low i dont know whats wrong with it. I hear the fuel pump come on so i dont know
Old Jan 29, 2016 | 04:13 PM
tbird6's Avatar
What is low fuel pressure? What is it reading? Do you know what is should read?
You need to fix the pump or restriction first.
Old Jan 29, 2016 | 04:27 PM
JagV8's Avatar
Which engine size?
May be worth checking the voltage as you crank, just to be sure it's OK.
Old Jan 29, 2016 | 05:32 PM
Datsports's Avatar
Does the 2002 have the fuel pump cut off in the left hand kick pannal ?
I had an 04 v6 trailerd in the other day the fuel pump had failed and it popped the cutoff switch! I reset the switch and the car started fine , but would not then restart hot only when cold and would run untill swiched off again ! Replaced fuel pump and was all good !
King Charles
Mar 25, 2016 09:12 PM
Computer Budda
Feb 1, 2016 06:23 AM
auburn2
Jan 28, 2016 08:51 PM
Josasaja911
Jan 26, 2016 06:02 PM
AzRon
Jan 24, 2016 07:45 PM
