Help on OBDii/EOBD tools
Old Mar 10, 2014 | 01:06 PM
Gimby's Avatar
Default Help on OBDii/EOBD tools
Hello Members
(Admin -may want to move to general forum as believe applies to all)
I am looking at OBD diag and remapping tools for 2005 S-type 2.7tdi but thread probably applies to all makes to some degree.
OBD thread probably too long so remapping to follow as linked thread etc.
Have checked forum Gen/model + wider www search and results vary from 2-8years old. hence post.
From a Computer/Networking/Telecoms background I understand as follows:
Background before questions
  1. Basically OBDii = EOBD (US vs Europe spec) where as EOBD2 is Enhance spec and manufacturer/model specific
  2. Early diag tools pre-OBD, vary and are vendor specific, but *ODB & OBDii standards unify this to common standard.
  3. *These latter standards (assumed) are based around IP protocal - Communication layer - wired/USB/Bluetooth/wireless etc.
  4. Assuming based on IP, then the 7 layer OSI model should apply, but put simply:
    1. the physical interface (wire and whatever socket type)
  5. Handheld vs Iphone/Android vs Laptop - consider the same. i.e they are processing units that with the right app, can interpret data sent by the cars ECU. You pay less for a bluetooth/wireless/USB connection type than a dedicated Handheld because you already have the processing unit etc.
Questions
  1. Have seen very cheap Bluetooth/wifi dongles with s/w from £5-£10. reviews state: Claim Elm v1.4 or 1.5 but tend to be V1.1 standard. Given above background then physical connection and communication between ECU and device should be somewhat transparent and issue falls to application.
    • i.e seen Jaguar scanner at £1200 for laptop with USB and S/W. Ergo S/W must be the difference.
  2. Have checked VGate products (Chinese) but look proper rather than knock off - any experience out there?
I think you may have got my point by now i.e. if the ECU communicates to device of choice then what should be the very simplest of tasks to transfer data and codes should be a given????
Sorry for V-Long post but simple X vs Y product mentions don't do it, given the above.
Finally, not after Gadget products/software that shows flashy dial screens (skirt lifting) but no real info. Looking to find and solve problems etc
again - long post - sorry
Thx Paul
Old Mar 10, 2014 | 01:23 PM
JagV8's Avatar
No IP.
Just read the existing threads here and in General Tech as far more info and accurate at that is there.
Also see the Cloned dealer scan tool thread. You can download the manuals if you choose and have lots of spare time.
Old Mar 10, 2014 | 03:41 PM
tbird6's Avatar
Yes. Forget about any remapping software.
Any cheap ELM327 will do. I have seen the different versions like V1.4 and I did get the highest one I could find. Which I think was V1.5 and it does look like V2.0 is out now.
Then pick the software you like. I run Scan XL on an old laptop. As you will find out there are special packages to read brand specific codes. I picked Ford and it does pretty good.
Yes the Bluetooth will also work and is cleaner to use. So far I have stayed with wired version and added a right angle adapter to get the cable away from my feet. I have not needed to use it very much yet so not a big problem for now.
If you are interested here is some in depth explanations.
Elm Electronics Help - OBD Circuit Tips
Old Mar 11, 2014 | 12:25 PM
Gimby's Avatar
Thanks for post, will investigate further
Old Mar 11, 2014 | 02:25 PM
Originally Posted by Gimby
Hello Members ............
Welcome to the forum Paul,
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see.
In return you'll get a proper welcome and some useful advice about posting to the forum.
SD96XJ6L
Dec 27, 2025 09:58 PM
Johnken
Apr 8, 2018 10:21 AM
Glenn Barickman
Oct 1, 2015 04:09 PM
Mark SF
Sep 28, 2015 01:51 PM
