Oil Leak
Old Apr 7, 2013 | 12:24 PM
Stype student's Avatar
Default Oil Leak
Hi everyone,
I went to check my oil the other day and noticed some leakage from a plug thing on the engine. Just wondering what this is and if I can do a simple replacement of the seal or something.
Thanks much,
Old Apr 7, 2013 | 05:01 PM
police666's Avatar
see this thread here, it looks like vvt sensor
https://www.jaguarforums.com/forum/s...e-cover-75557/
Old Apr 7, 2013 | 05:32 PM
Thanks. Do you think I have to look for a coil or plug thats bad along with replacing the seal?
Thanks!
Old Apr 7, 2013 | 06:03 PM
police666's Avatar
while your in there you might as well check the plugs and coils for any sign of oil and replace ALL gaskets, personaly, for what they cost, i would change the plugs too.
Old Apr 7, 2013 | 07:37 PM
Mikey's Avatar
I think I'd wipe the sensor and area clean and see how long it takes for new oil to accumulate. Might not be worth bothering with.
Old Apr 7, 2013 | 07:58 PM
Six Rotors's Avatar
Might be worth checking the crankcase ventilation system too--excess pressure is always good for creating oil leaks.
Old Feb 14, 2014 | 04:20 PM
Jagxf2014's Avatar
I haven't drove my jag in about 2 months I turn it on and backed up oil started leaking
Old Feb 14, 2014 | 04:32 PM
police666's Avatar
From where
Old Mar 11, 2014 | 06:42 PM
jjohns26's Avatar
I just replaced the valve gasket, spark plug seals, as well as the VVT gasket. It's only been a few days, but I'm seeing oil slowly seep out of the inside (between gasket & VVT). WTH? I'm assuming this is pretty normal with these cars, just like the other "common" problems. Should I just seal it off with some Permatex?
Two Pictures below: Passenger side, which I just replaced and then the Driver side, haven't gotten there yet!
Passenger Side: Just Replaced
Driver Side: Not Done Yet
Old Mar 11, 2014 | 09:42 PM
abonano's Avatar
Actually, not normal I hate to say. Did you use Jaguar OEM VVT seal or aftermarket?
Old Mar 11, 2014 | 09:48 PM
jjohns26's Avatar
Question
I ordered Part # AJ82856 Valve Cover O-Ring from Rock Auto
Old Mar 11, 2014 | 10:05 PM
jjohns26's Avatar
The seal appeared to be identical to the old one I pulled out, same Jaguar part #. Is it possible that the seal is defective, or maybe I didn't clean the VVT good enough? When I first noticed the leak, it almost looked like the oil was coming from the sensor itself, right below the plug. Don't even know if that's possible, but there was some oil on the VVT head. Is there more than one seal for these things? I dunno.... still learning about this car, and I'd had it almost 2 years.
Boeingtravel95
Sep 14, 2015 05:01 PM
jaggermang
Sep 8, 2015 07:07 PM
OkieTim
Sep 8, 2015 04:48 PM
Dymaxxion
Sep 4, 2015 02:40 PM
OkieTim
Sep 2, 2015 12:48 PM
