help solving problem code p1646
P1646 - Jaguar
Type Powertrain - Manufacturer Controlled DTC - Manufacturer Controlled
Description
Fuel pump relay 2 - malfunction
Cause
Wiring, fuel pump relay
Where do I start?
Description
Cause
Where do I start?
It's not that meaning. Consult the forum and/or codes PDF and/or JTIS. (It's an O2 code but those sources give you all the possible causes as well.)
What was the (faulty) tool that gave you that bad meaning?
Basic scanners can give misleading results with Jaguars but generic code lookups can be even more dangerous! Here is the Jaguar extract for P1646:
If the vehicle runs, you can reasonably ignore ECM failure as a possible cause and concentrate on the HO2 Sensor.
