Hey Everybody I知 New to the Forums and need some help
Old Dec 23, 2021 | 06:41 AM
WockyTang's Avatar
Default Hey Everybody I知 New to the Forums and need some help
Does Anyone know where the Starter for a STR 2004 4.2 V8
I am trying to locate my starter so I can check it and replace it
Old Dec 23, 2021 | 11:06 AM
joycesjag's Avatar
Welcome to the forums!
What is your starter doing or not doing? Starters are not that common to go bad on our beloved S Types.
Old Dec 23, 2021 | 11:17 AM
NBCat's Avatar
The starter on the AJ34S is located under Bank 1 cylinder head, on the RH side of the vehicle.
How many kilometres/miles are on the vehicle?
What are the symptoms?
Old Dec 23, 2021 | 11:28 AM
WockyTang's Avatar
Im not so sure if it痴 really the starter doing it but I was told it could be my start.
when I turn the key to start the car, times before turning turn off on. I brought a new battery and went and check my alternator Nd it was fine
but it still has a little lag when I知 turning it on , but after it痴 on it runs great
just worried about the start up lag
Old Dec 24, 2021 | 10:53 AM
S-Type Owner's Avatar
Step #1 is to check the status of the charge on your new battery. A fresh battery off of the shelf will rarely be at a full charge. If you are not confident checking the battery, most parts stores will do this gratis...
Old Dec 25, 2021 | 04:10 AM
WockyTang's Avatar
thanks A lot , I really felt like that was the problem, because I didn稚 have this issue before with my other battery - I went to autozone to charger my battery to see it would change the way it starts up Nd they gave me a new battery off the shelf since I had warranty. After that I kept having electrical issues- car shut off on me - I went to charge that battery Nd it died on me again after that . Now I recently got a new battery again and it痴 been working perfect since . But today when I start it up will judge if the start up will be lagged ...... I really felt as if the other battery was the problem
Old Dec 26, 2021 | 09:47 AM
Let us know how you get on... You also might want to stop by the New Members Forum and post a brief "Intro" as it is the expected thing to do here on the forums.
Xjeffs
Oct 16, 2020 07:44 AM
fliha
Mar 15, 2013 12:27 AM
maikal_0011
Nov 5, 2011 11:18 AM
jamiegingerbater
Jul 27, 2011 08:11 PM
wnlewis
Jul 28, 2009 11:23 PM
