HID Fogs
Old Mar 8, 2011 | 05:44 AM
achysklic's Avatar
Default HID Fogs
I have read many many post on this so I'll try to keep this simple.
I have a 2005 I believe the Fogs are H11 is there a direct plug and play Hid kit for the Fogs?
If so what brand?
I like ddm tunning kits but I have no idea if they are plug and play.
As always thanks for the replies
Old Mar 8, 2011 | 06:28 AM
JOsworth's Avatar
I'm sure George will jump on this....
Yes, the fogs are H11...
Just installed a DDM kit on my 300 for the low beams... It took all of 15 minutes! The ballasts are a bit large but robust. I bought the "extras" yet it was only a fraction more than high quality halogen bulbs.. and the light output is MUCH better. Then again, the 300 does have the projector lenses standard that makes them a natural for the HID's.
Old Mar 8, 2011 | 08:59 AM
androulakis's Avatar
What Jeff Said...
DDM is owned by a good friend of mine, good stuff...
I'm not sure what the proper bulb size is on an 05. It's H3 on a 2003.
Defintely get the $4 ballast mounting brackets as an option. Other than that it's pretty straight forward.
Let me know if you have any quesitons.
Take care,
George
Old Mar 8, 2011 | 09:08 AM
achysklic's Avatar
Yeah I am really impressed with ddm...They just don't list a kit for Jaguar so I am concerned am I going to have to cut and splice wires or will it be plug and play?
Also should I get 35w for the fogs and I want them kinda blueish like the factory HID'S so maybe 6000k?
Thanks for replies guys
Old Mar 8, 2011 | 09:23 AM
There is no real any car specific Jaguar kit.
Well, you MAY have to cut the end off the factory fog plug and wire it to the ballast. I think you don't have to with the h11 kit. I did, because it makes it much easier. I used male / female quick disconnects and heat shrunk them. I put a set of males on the factory plug so I can also replace it if needed.
I have 6k DDM in head and fogs. It's a bit too blue for my taste. 4300 is a match to factory headlights. Don't do 55w in a fog light. There isn't enough room to properly dissipate heat and I fear you'll kill bulbs quickly.
Take care,
George
Old Mar 8, 2011 | 10:11 AM
achysklic's Avatar
I am getting ready to order, H11 35w they don't offer 4300k they offer 4500k would this be the same as the factory HID color?
also no $4 bracket is listed a $12.50 HID harness dual in dual out is availb.
Do I need it?
they also offer a error eliminator for $15 what about this?
Sorry for the questions just want to get it right.
I was able to find the $ 4 brackets
Old Mar 8, 2011 | 11:17 AM
jag79's Avatar
What are those brackets for? I never remember using them for the install.
Old Mar 8, 2011 | 12:04 PM
Brackets:
http://www.ddmtuning.com/Products/HID-Bracket-FullSized
For mounting the full sized ballast the "real' way rather than with double sticky tape.
No harness or HID warning elminator needed for 35w fogs on the S-Type.
Take care,
George
jagent
Jun 5, 2022 02:18 PM
kingdom worker
Nov 14, 2020 03:47 PM
gunlocators
Sep 30, 2015 08:05 AM
redrover41
23
Sep 25, 2015 01:33 PM
