high rpm is this normal, what spark plug to ues
Old Jan 27, 2010 | 12:14 PM
jaguars-type's Avatar
Default high rpm is this normal, what spark plug to ues
when i turn on my car the rpm would idle at (1) and stays there, is this normal, while I'm at a red light or stop sign I'll let go of the brakes a little and the vechile would move forward with out me giving it any gas so I'll get a grinning noise from the brake pads.
I also what to change the spark plugs and was looking at NGK G-Platinum
Do you guys think that these plugs are correct for a 2003 s-type 3.0
Old Jan 28, 2010 | 03:44 AM
JagV8's Avatar
What is (1)? 1000? If so, not normal if the engine has warmed up. Should be more like 650-700ish. Does it still idle at 1000ish when warmed up? You have a fault that needs fixing if so (may be running rich so may destroy cats; probably won't pass emissions tests).
I'd plan to get an OBD tool that can not just read codes but can also show you what the car's sensors are doing. And tell you whether the car's running CL (closed loop).
Autos do normally creep a bit. "grinning" is priceless lol
Don't put in the wrong plugs. Expect endless problems if you do until you replace them with the right ones. The spark plugs and much else are in the stickies (see forum top). Well worth your while to do lots of (free!) reading.
And read old threads here. Likely to save you soooo much cash.
How many miles on the car?
Old Jan 28, 2010 | 11:10 AM
It stay in idle at 1000 all the time,even after warm up. Car has 67,000 miles
Old Jan 28, 2010 | 11:42 AM
JagV8's Avatar
I'd start with OBD readings in the hope of avoiding changing lots of parts until you happen to change the right one(s). Or take it to a competent tech who understands the S-Type and can properly diagnose what's going on. You're not so much looking for DTCs (codes) - though you may have them - but rather at what the car's deciding to do and why.
I've posted quite a bit about OBD if you want to do this yourself, and there's lots on the net, but be prepared to spend time reading as it's a big subject - and in due course more time getting OBD data.
Old Jan 28, 2010 | 03:33 PM
JOsworth's Avatar
Heed the "Jag-ster's" advise(Hope you don't mind the nickname JagV8)... He's like the local OBD expert...Lot's of knowledge. All he (and the rest of us for that matter) asks is that you do some homework first so you have a basic understanding. If it is too much, that is OK as well, since OBD cars in general can get pretty complicated to diagnose let alone fix. In that case be prepared to take it to a QUALIFIED technician. I also agree that idling at 1k is too high and points to an underlying issue.
BTW JagV8: My brakes made a "grinning" sound this morning when a dork ran out of talent on a slushy exit ramp in a PT Cruiser. Man do I love the ABS and DSC in these things....
Old Jan 28, 2010 | 03:42 PM
JagV8's Avatar
How was your heart rate? A bit faster than normal?
I'm NOT going to enquire about brown stains anywhere LOL
I'm no expert, sadly, just struggled to get my head round it on other cars and trying to figure these out. Almost any name you like but go for John if you like
Old Jan 28, 2010 | 03:52 PM
JOsworth's Avatar
Yea.... All I thought is "S*it, it's my fault if I hit this moron!" But the good 'ol S stayed true and just scrubbed speed. No stains, to need to change clothes, it was totally predictable.
Thanks for sharing all the aquired knowledge, I know it helps quite a few people here...Heck it helped me trouble shoot the Caravan and save a bundle on a dealer visit. And Jag-ster it is.....LOL...
Old Jan 28, 2010 | 04:58 PM
Will today I removed the intake and value covers, what a job that was. The rear passenger coil had a bit of oil on it, so removing the value covers wasn't a waist of time. I still can't find anything online or on this sit about what spark plugs would work the best for my vehicle. I still need help guys I searched and can't find info
Old Jan 28, 2010 | 05:51 PM
JagV8's Avatar
Are you thinking that changing the plugs will affect the high idle? If so, care to explain why you think so?
Plugs aren't especially cheap but if you're not short of money then can't hurt to change them.
Old Jan 28, 2010 | 07:40 PM
No i don't think that the spark plugs are my high idle problem. The engine light is on so had the guy in autozone check it out for me and the codes P0301 thur P0306 came out so I started to remove one spark plug one at a time and they didn't look so good so I decided to put new plugs in. How much does each plug cost.
Old Jan 29, 2010 | 01:34 AM
JagV8's Avatar
Misfires on the 3.0 have been covered in multiple recent(ish) threads so follow them
Much more likely to be coils than plugs but change both. Get parts from a jag dealer unless you really know what you're doing. The costs of the wrong parts will be horrific.
Also be sure no air leaks, again it's all in previous threads.
And be aware that codes like that are merely clues that things are VERY bad. A proper OBD tool will tell you what the sensors are reporting to help you see what else is wrong.
Old Jan 29, 2010 | 10:00 AM
Do you guys know what the torque pressure on the value covers, spark plugs and intake are.
Old Jan 29, 2010 | 10:42 AM
tbird6's Avatar
Get the Jaguar JTIS (Jaguar Technical Information Service) repair CD/DVD. They are all over EBay for about $10. This is a must have for any owner and especially anyone doing repair work!!
Old Feb 9, 2010 | 08:02 PM
Boy did I have fun today, I'm still waiting for upper radiator hose and brake vacuum tub to turn her on. Does anyone know where I can find the clips that holds the vacuum brake hose to the intake.
Attached Thumbnails high rpm is this normal, what spark plug to ues-car-045.jpg
Old Feb 10, 2010 | 06:41 AM
Jon89's Avatar
What are the six green ovals shown in your photo? Are they the upper intake manifold gaskets? If so, they sure are smaller than I envisioned....
Old Feb 10, 2010 | 01:24 PM
Yes, the six green rings are for the upper intake gaskets, does anyone know where I can find the plastic clip that holds the brake vaccum line into place, the brake vacuum line connects to the rear of the intake.
Old Feb 10, 2010 | 01:32 PM
JagV8's Avatar
Can't a dealer get them?
Old Feb 10, 2010 | 01:35 PM
MyBlackCat's Avatar
I'm sure your dealer can get it, probably the only place that would carry it.
You could probably make something else work in its place from your local parts store.
Old Feb 10, 2010 | 07:25 PM
Does anyone know what they are called or part number
Old Feb 11, 2010 | 02:16 AM
JagV8's Avatar
Just call the dealer parts guy and explain where they fit and what the parts look like (size etc). The parts guy can look on screen but often they've supplied parts to their own people so know what you mean very quickly.
