>>>how to remove/change led display<<<
Old Mar 20, 2011 | 12:14 AM
sam2007's Avatar
Default >>>how to remove/change led display<<<
How to remove/change led display ,the one that shows mpg/ gearbox fault,etc. Has went out,this happened when i had a short blown fuse number 4 passenger side panel, after i cleaned the battery points and changed out 3 relays and 2 fuses including #4 this got the car running again, i found that my led readout is not working at all ,is it big job to change this out does this involve dashboard removal? Or just a case of accessing the speedo? .. Thanks to all
Old Mar 20, 2011 | 08:17 PM
bfsgross's Avatar
Yer better off asking one of our Jag techs i.e. Brutal, etc.
Old Mar 21, 2011 | 01:45 AM
JagV8's Avatar
Is it not in JTIS? (Some cluster issues are on here, too.)
Old Mar 23, 2011 | 01:26 AM
sam2007's Avatar
can you tell me about them or post link where should i start looking re. the problem
Old Mar 23, 2011 | 01:46 AM
JagV8's Avatar
Did you look in JTIS?
Old Mar 23, 2011 | 05:41 PM
sam2007's Avatar
I dont have it , i need a 64bit or 32 bit version the one posted on this site is 16bit will not work with win7 64 if you have a link to same please post thanks
Old Mar 23, 2011 | 10:45 PM
sedakai's Avatar
It could be a fluke and may be the same reason mine went out.... there is a resistor on the circuit board that is notorious for breaking loose. one of the members here posted a guide on how to fix it. pulling the dash apart wasn't too bad, i think i broke the clips on every vent but the superglue back good as new. anyway im only 18 and i fixed my display in 30 min with no automotive background. I might not be a good example though...everyone says im crazy for working on my jag =)
Old Mar 24, 2011 | 01:00 PM
tbird6's Avatar
Install Vitual machine on your 64 bit Win7 computer. It's free from Microsoft and it works fine running JTIS on my Win7 Ultimate N 64bit machine.
GGabriel
Nov 22, 2018 03:53 AM
philwarner
Jan 31, 2016 09:36 AM
dstary
Sep 19, 2015 09:47 AM
sklimii
Sep 5, 2015 06:04 AM
