how to remove oil pump 2000 V8
You will have to pull the front engine cover off. So u will need to make some room in the front of the motor (usually the fan has to be pulled) To pull the front cover off u will need to take off the valve covers. I am not sure if you need to pull the oil pan (s) to get to the oil pump.
