I Have two problems NEED HELP!!
Old Apr 14, 2008 | 07:14 PM
FactoryJaguarTech's Avatar
Default RE: I Have two problems NEED HELP!!
The variables with all those lights is hard to say. Has the car ever been in an accident?
The leak you are hearing is probably the valve bolted to the right side cam cover. Push it down a little with engine running and you will hear the noise change. This, btw is not causing your other problem and is going to be secondary to the first problem.
Could be a network problem, a module, a loose relay, loose ground, loose connector. loose pin in a connector. Need to know what codes are in there and if there is a module that is not communicating. Best thing is to get it to dealer without shutting it off. That way they can see the problem and scan it with fault present. If a module is not communicating, much easier to diagnose. Just tell them, do not shut it off and get it scanned right now.
Old Apr 15, 2008 | 06:25 AM
Lol that definitley makesit hard.
Did you just detail the engine?
Pm me last 6 of your vin.
Clamdigger
Sep 12, 2015 03:43 PM
dragonfly777
Regional
Sep 8, 2015 01:39 PM
mcdutch
Sep 4, 2015 03:38 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
