i930 scanner DTC B1264
Old Jan 11, 2016 | 12:40 PM
cully's Avatar
Default i930 scanner DTC B1264
Hi, forum readers, I have just received my i930 scantool, tried it on the Jag (2003 model 3ltr Auto petrol) and don't have any pending codes of concern.
Scanning through the menu I did come up with this code:
Foot servo motor circuit failure B1264
I have had an issue with the heating but not serious enough to be a concern. (the weather isn't as cold in the uk as it gets in the USA)
The question is "Does this situation require resolving / can it manifest into some bigger problem and if so how?"
I have looked on the JEPC and cannot pick up the servo motor and there isn't much info in the search section or on google
Any advise appreciated.
cully
ps. only had 20 minutes use with this scanner but it seems to have quite an extensive menu.
Old Jan 11, 2016 | 01:44 PM
JagV8's Avatar
Clear the code and see if it comes back / when.
Meanwhile get (free download) workshop manual (which has full details of it).
Old Jan 11, 2016 | 02:49 PM
cully's Avatar
Thanks JagV8 I will check code out tomorrow.
I had forgotten about the JTIS which I downloaded some time ago, but haven't had a need to use it.
I have just tried to bring JTIS up to view on the laptop and it is refusing "invalid path" I have recently downloaded windows 10, which shouldn't have any bearing on above problem but something has changed and it was a nightmare getting it downloaded originally.
I will attack it in the morning
Thanks again
Old Jan 11, 2016 | 03:35 PM
JagV8's Avatar
Win10 will very likely be the culprit.
Old Jan 12, 2016 | 10:04 AM
cully's Avatar
Default Lost JTIS
Hi;
I upgraded my windows from 7 to 10 last July time and having just had a need to check out a Jag code I find that I have lost JTIS from my computer Not sure when this occurred but when I try to bring it up I get "invalid path" box.
JagV8 suspects the upgrade being the reason!
Any thoughts on above from computer literate readers would be welcome as I am lost.
cully
Old Jan 12, 2016 | 11:14 AM
Jumpin' Jag Flash's Avatar
From: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
Go to the windows desktop and do a search for JTIS. Or manually look through your file system using Windows Explorer.
If you can't find it, IMHO probably best bet is to download again and reinstall it.
LstFord
May 28, 2022 07:26 PM
Ubad2
Dec 27, 2015 11:00 AM
Rocky15
Dec 22, 2015 06:50 AM
snowball
Dec 18, 2015 10:07 AM
davecabezo
Dec 16, 2015 08:28 PM
