Ignitor for Xenon lights out............
Old Nov 21, 2011 | 08:02 AM
phd12volt's Avatar
Default Ignitor for Xenon lights out............
Passenger ignitor went on passenger light this weekend.........thank god it wasnt the ballast. Spent 3 hours swapping ballasts and checking all the wiring, come to find out it is just the ignitior on the rear of the bulb causing the outage.
Called up Nalley and Dan, they will have it out to me tomorrow. 102 shipped for it. UGHHHH
So if anyone else has issues check your ignitor before ordering ballasts.
Old Nov 21, 2011 | 08:32 AM
RBing's Avatar
Would the light come on at all?
My wifes will come on but then go off shortly. If she turns her lights on and off it will come back on, stay on for about 30 seconds and then go off.
Old Nov 21, 2011 | 08:41 AM
phd12volt's Avatar
factory xenon or aftermarket?
Old Nov 21, 2011 | 09:07 AM
RBing's Avatar
Factory but I did replace the bulbs in July with no factory.
Old Nov 21, 2011 | 12:40 PM
phd12volt's Avatar
the ignitor on mine went out a few times while driving, and then onc i cycles the lights it came back on. Finally it quit all together. I removed the front bumper and swapped ballasts, and also swapped lights side to side. It was then i started looking inside the lights as it wasnt a wiring issue at all with the vehicle. I finally switched the ignitors around and that is where the issue came from.
It is 102 shipped from Nalley for the part.
I have a pic of what the ignitor looks like i will post in a few.
Also make sure the ignitor is seated correctly. The 4 tabs must be locked in correctly. And then plug it in. If you look at the ignotor plug, there is a micro switch inside of it that moves to lock the light in.
Old Nov 21, 2011 | 01:02 PM
RBing's Avatar
Yes, please post a pic if you have one. I have no clue what an ignitor looks like. I really hate having to take the front bumper off on this thing again. It's not hard but one of those things that's just a pain in the rear. Also, having to either put it back on or waiting until you get the part but you have to figure out what it is.
Old Nov 21, 2011 | 01:16 PM
RBing's Avatar
Ok, so I looked up the ignitors and I remember seeing that. I believe it was on the back and you had to twist it back on. Maybe I'm wrong but I do remember it.
Question, is there a way to test the ignitor itself? I can' remember if it's wired in or if I can use the drivers side to see if that's what it is.
Old Nov 21, 2011 | 02:40 PM
phd12volt's Avatar
Thats the ignitor
Old Nov 21, 2011 | 02:41 PM
phd12volt's Avatar
you can plug the drivers side into the passenger wiring......same plug on both sides. And vice versa.
Thats the first thing i did to verify it wasnt a wiring issue in the vehicle.
Jpav27
Jul 31, 2022 06:43 AM
afterburner1
Dec 16, 2015 12:12 AM
avern1
Sep 8, 2015 06:25 PM
Mosers63
Sep 6, 2015 02:53 PM
XCrossWindsX
Sep 5, 2015 10:58 PM
