Inner door handle piece replacement parts?
Old Jan 3, 2024 | 01:58 PM
mikesbaron's Avatar
Default Inner door handle piece replacement parts?
2003 model and the innder door handle bezel/insert is cracked on both front driver/passengers sides of the door. Is there an easy, common model (Ford?) replacement for these pieces? Or are like some Jap door handle parts does anyone make replica replacements?
Old Jan 4, 2024 | 07:32 AM
joycesjag's Avatar
Welcome to the forum Mike. Ebay has quite a few used and new starting around $35.00.
Old Jan 4, 2024 | 08:50 AM
clubairth1's Avatar
Community Influencer
Jaguar parts are determined by the last 6 digits of your VIN. You need that to get the right parts. That part also comes in many colors depending on your interior.
I will assume yours is "Warm Charcoal" or black.
Looking at the JEPC/J-Part catalog there are several different part numbers again depending on your VIN.
Possible part numbers are; Note these are listed for VIN's above M45255. This is the common number you see for what's called the "Face Lifted" S-Type. Which your 2003 is but again do check your VIN!
Drivers side-XR825068LEG. Note the LEG determines what color the part is.
Passenger side-XR825067LEG.
But they are expensive at $40-$50 each!!
I do see used ones on EBay for about half that but be aware those are plastic parts which are now over 20 years of age. They are just all brittle at this time. So a used one might not last very long.
Old Jan 8, 2024 | 12:51 PM
mikesbaron's Avatar
Thanks for the help, you are great!
dborthwick
Nov 3, 2018 06:52 PM
dborthwick
Oct 13, 2018 10:39 AM
Padrino
Feb 5, 2015 04:12 AM
XJ6_1994_J40
XJ40 ( XJ81 )
Jun 2, 2008 12:47 PM
