installing an aux connection
Old Nov 17, 2023 | 12:11 AM
RA052426's Avatar
Banned
Default installing an aux connection
I have a 2000 S-Type and the tape deck is erratic when trying to use a tape to connect to my IPHONE. It is hard to find a Stereo repair company in the Coachella Valley (Indio, CA) and I have seen YOUTUBE videos that show how to install a CD/Aux connector that would be a decent workaround.
Would love to here from someone that has done that, if so successfully.
Thanks.
Tim
Old Nov 17, 2023 | 05:27 AM
Rober2's Avatar
Hey Tim
This is not to answer your question but to tell you what I did in my 01. So as to keep everything original in that part of the car, I just used one of these.
Old Nov 17, 2023 | 08:02 AM
RA052426's Avatar
Banned
Default Installing au in car
Thanks. Why did you choose this particular one? How long have you had it?
Awesome, easy
Old Nov 17, 2023 | 03:18 PM
Rober2's Avatar
I cannot remember what brand/model i got. Its been 2 years. I saw one in utube and ordered. They are cheap anyway. I am sure the new models/brands will be better. I am happy with mine but maybe will get a new one with more usb ports. We only have one lighter socket.
Old Nov 17, 2023 | 03:20 PM
Rober2's Avatar
By the way, it is best if you add your car details in your signature.
Old Nov 18, 2023 | 03:50 PM
LLLA's Avatar
Thanks.
Tim
Do you have a 6 CD changer in the trunk?
Old Nov 20, 2023 | 06:51 PM
LLLA's Avatar
Sorry friend, wasn't trying to leave you on a cliff hanger. But having a 6 changer and a pre-2002.5 model is where I could potentially help.
Easiest Solution
If you have the cd changer, there are devices you can purchase which will take the place of the changer and provide you an aux input. This will render your CD changer inop; (See here) I use this solution in addition with a bluetooth receiver and find it fantastic.
Now be aware, the audio feed coming from the CD changer to the headunit is digital, not analog. This means you cannot simply tap into feeds between the two and need a box (as in the listing above) to act as a middle man.
Option 2
The feasibility of this option depends on your electronics experience. A quick google search will yield countless articles showing how folks have tapped into the pre-amp circuit feed coming off their tape decks and used these as an aux input. It does require the disassembly of the head unit, but with the plethora of information out there, it can be done with some patience. I would HIGHLY recommended visiting a pick a part and purchasing a practice unit before attempting to modify your current headunit.
Option 3
Pre 2002.5 S Types use Ford's standardized headunit platform. (You may have noticed the similarities to other FoMoCo models). There are sellers on eBay with modified versions of these headunits with an added aux input. This is acheived by tapping into either the preamp circuits for whatever input is available, whether it be the turner, tape deck or CD player. This is the toughest option, as older decks (such as the one used in the early S Types) aren't typically listed. However, I have seen vendors who will modify your existing deck for a fee.
Hope this helps, let me know if you have any questions.
Old Nov 21, 2023 | 07:55 AM
scrannel's Avatar
Hey LLLA. I have a 2008 Alpine/6 changer, so presume item # CTVFOX001 won't work for me? Thanks
Old Nov 21, 2023 | 01:00 PM
LLLA's Avatar
Unfortunately you are correct, the solution above is only for 2002 S Types and below.
The thread below looks to have some good info for your model.
https://www.jaguarforums.com/forum/s...03-gps-204339/
Old Nov 21, 2023 | 02:50 PM
scrannel's Avatar
Thanks LLLA! Checking it out...
Old Dec 9, 2023 | 12:18 PM
kiloslanga's Avatar
Thanks.
Tim
I use this https://www.incarconnections.co.uk/j...x001-ipod.html and it’s cd quality no fm static. I then run an rca cord to this adapter
Amazon Amazon
no power needed and a thin 3.5mm audio cord through the drawer to the right of the stereo so it looks factory when phone is in the drawer playing music. You could just run a longer rca to 3.5mm from the jaguar aux adapter but it would be a much thicker cord and you’d need to drill a hole. Either way pretty awesome stuff.
LLLA
Feb 14, 2022 09:40 PM
harryc
Jan 15, 2019 01:36 PM
randyb
Sep 21, 2011 02:31 PM
mknapper1
Sep 17, 2011 12:18 PM
worldrider
Apr 2, 2009 10:45 AM
