Instrument cluster lock out?
Old Aug 21, 2014 | 11:22 PM
webbeing's Avatar
Default Instrument cluster lock out?
Hello,
The car is a 2000 S-type v8, I understand that an instrument cluster from another car would not work. But would it also causes the security system to "lock out" the car requiring a tow to a dealer?
If the car is "locked out", would installing the original cluster un-lock the car?
Many thanks.
Old Aug 22, 2014 | 01:47 PM
tbird6's Avatar
Yes. The car should start and run with the wrong cluster but you should get beeps and the cluster won't work much if at all.
Have you tried starting it with the replacement cluster?
Old Aug 22, 2014 | 02:04 PM
JagV8's Avatar
It sounds a risk even to try it. Fixing whatever's wrong with the existing cluster looks better.
Old Aug 23, 2014 | 12:20 AM
webbeing's Avatar
Yes, I am working on fixing the original cluster. But just in case I bought a replacement one from the 'bay. I needed to verify at least the replacement one has some functionality before I send it out for "recode". I have not install the replacement cluster (bought from ebay) yet, for fear of the "lock-out" issue. From "Tbird6"'s answer, it's o.k to try.
Thanks folks.
Old Aug 23, 2014 | 01:30 AM
JagV8's Avatar
If it goes into anti-theft you're going to be stranded. Let us know (if you risk it).
philwarner
28
Jul 11, 2017 10:21 AM
jluckcuck
Nov 6, 2015 07:49 AM
millertic
Sep 30, 2015 08:11 PM
Bigvettefreak
Sep 28, 2015 03:03 AM
