Start with correct available voltage. Use a voltmeter and check the battery voltage across the terminals with the ignition in the OFF position. There should be a minimum of 12.6 volts available for all modules to function correctly.
Battery - bizarre Only 12.4v
And I charged overnight only a week ago with an Intelligent Pulse Charger
Am recharging now.
Battery - recommended for car - only 4 years old.
Good point
Maybe the battery is going - but down here in the SE Cote d'Azur of France, the weather is very mild and in theory less strain on the battery
Restricted performance doesn't usually throw any codes. Most likely suspect is potentiometer on the throttle body.
🤦♂️ i thought you knew better than this
rp is generic message for like a dozen different faults and they have different failsafe modes. lean feedback loop limits you to 3k until ltft goes under 18.5
I am aware of some OE batteries that have lasted for very extended periods, given a mild climate and non-maltreatment... I have heard that the current crop of auto batteries are not as long lived as the originals, given changes in plate design/materials.
At four years old, the battery should always be suspect, until proven otherwise.
Thanks - I'm sure you are right.
After overnight charge with Intelligent pulse charger it was only showing 12.6 volts.
Originally it showed 14.6v and held it for some time.
