J gate problem
Old Aug 28, 2025 | 10:38 AM
kr98664's Avatar
Originally Posted by tgmjfj
What if the only problem is that the shift lever will not go into second gear (which it does in the last photo from Dusty-D?
I have a 2001 3.0 with this problem.
Coincidentally the starter will not work when the car in in Park, but it starts ok if the car is left in Neutral after stopping. I think there must be a switch somewhere which detects the shift lever position...
Lots of good details in previous posts in this thread.
For not going into 2nd gear: I'd suggest removing the console cover and disconnecting the cable from the J-gate mechanism. Then you can determine if the problem is within the J-gate itself or the cable is not moving properly. A stretched cable is one possibility, or that infamous cracked plastic block in the J-gate. Make sure the mounts are secure at both ends of the cable. Be sure to read the TSBs in those previous messages.
For the no-start, there is a "transmission range sensor" on the side of the transmission, where the shift cable attaches. This picture, shamelessly stolen from eBay, shows this component on the US driver's of the transmission:
Take a look at the wiring diagrams here, near the top of the page:
JagRepair.com - Jaguar Repair Information Resource
Figure 04.1 shows the transmission, and 02.1 has the starter circuit. This sensor has two somewhat independent functions, as seen in the upper right corner of 04.1:
One function lets the starter engage only when the transmission itself is in P or N. This is feedback from the transmission, NOT the lever.
The other function is to provide feedback to the Powertrain Control Module as to which gear is selected. Once again, this is feedback from the transmission, NOT the shift lever. I'm not 100% positive, but believe this sensor also provides the feedback for the indicator lights on the J-gate.
When starting in neutral, does the N illuminate at the base of the lever? I'm pretty sure yours will. What about when in park? Does the P illuminate then? I'm thinking most likely not. Please confirm if those indicators are lighting up properly. That should help with further troubleshooting.
jrb53
Apr 26, 2017 07:16 AM
crt_ben
22
Mar 6, 2015 05:50 AM
Unseenthings
Sep 14, 2014 07:31 PM
JWT
Jun 29, 2013 09:01 PM
Robinb
37
Jan 6, 2013 09:52 AM
