Jaguar Heater Blowing Cold Air
Old Jun 8, 2011 | 02:08 AM
dips2907's Avatar
Default Jaguar Heater Blowing Cold Air
Hi,
I have recently got my Jag S-type year 2000 v6 3.00 ltr car repaired for a broken coolant bottle. The Air conditioner seems to work perfectly fine. It is the heater which is giving me griefs. I have been reading few forums but does not explain as to why after changing the coolant bottle the heater stopped to work in my situation.
Can someone kindly guide as i am anxious and would have great deal of information before i go back to the mechanic with added info?
Thanks,
Dips
s-type , V6, 3.00 ltr, year 2000
Old Jun 8, 2011 | 03:00 AM
JagV8's Avatar
Sounds to need bleeding. Common issue so use Search
Also check the FAQs as they do cover this sort of thing if you look.
Old Jun 14, 2011 | 04:32 AM
dips2907's Avatar
Thanks Jagv8 for you quick reply.
I have taken my car to few Mechanics(not the Jag Specilists), and they don't seem to have a clue as to where to locate the heater valve. I, too have searched the forum and could not find any thread specifying the exact location of the value and/or the procedure to release the air lock from the radiator.
Can you be kind enough to provide me with (probably a forum link) or procedure to do that on my car, if i were to rectify this issue myself.
I have been quoted few hundred bucks just to release the air lock, which i think should be a quick solution, if i were to do it myself.
Thanks, Dips
BrentGardner
29
Dec 16, 2024 12:13 AM
Xj812
Oct 26, 2015 05:04 AM
johanasu
Sep 3, 2015 12:39 PM
mikebaker3
Aug 31, 2015 10:44 AM
casepie
Aug 30, 2015 09:49 PM
