Jaguar S beeping when moving
Old Jul 16, 2016 | 06:02 AM
jacknk's Avatar
Default Jaguar S beeping when moving
Trying to help friend with a 2006 Jaguar S. The problem is the car starts beeping when you reach approx 5 mph. It will do it in drive and reverse.
I have seat belt fastened so that should not be the problem.
Any ideas would be appreciated.
Old Jul 16, 2016 | 08:44 AM
Welcome to the forum jacknk,
I've moved your question from General Tech Help to S-Type forum. Members here with the same model will be able to help.
Old Jul 16, 2016 | 10:18 PM
Datsports's Avatar
does the beeping come from the rear parcel tray ?
does it sound like the parking beeper ?
if so that would lead to a potential reverse parking sensor/ECM issue .
check the boot pan for water .
Old Jul 17, 2016 | 06:57 AM
jacknk's Avatar
The beeping comes from the front. I have turned the parking sensors off. No water in the boot.
Old Jul 17, 2016 | 09:00 AM
Mikey's Avatar
A faulty parking brake will cause this beeping, but there should be a warning light/message also.
Old Jul 17, 2016 | 09:46 AM
jacknk's Avatar
There is a faulty parking brake warning. He said something about this was disconnected and he was not getting the beeping until he changed the battery. I was thinking it was the pb also but according to him it is not.
He said someone else disconnected it, I don't know enough about the car to see if it is disconnected or not?
Old Jul 17, 2016 | 10:43 AM
Mikey's Avatar
It needs to be fixed one way or the other. The warning means that it's not functioning properly. If you can't DIY, find a trusted indy mechanic or a dealer.
BTW- when asking for assistance, it helps to provide all the info up front.
Old Jul 17, 2016 | 11:49 AM
jacknk's Avatar
Where can I find a good DIY on the PB? Thanks
Old Jul 17, 2016 | 04:27 PM
Jumpin' Jag Flash's Avatar
From: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
+1
Old Jul 17, 2016 | 04:48 PM
jacknk's Avatar
To me this is kind of a mystery. I suggested to him that it was the parking brake and he said it had not worked in a while that he did not want to get it repaired due to cost. He stated that the car had just started making the noise when he had a new battery put in. He is an older gentleman and I was trying to help him.
I can do basic repairs but don't know anything about the EPB.
Old Jul 17, 2016 | 05:49 PM
Mikey's Avatar
Do a search on this site, there's probably 2-3 discussions on every possible fault.
Install JTIS (factory mtce. manual) from stickies at the top.
Old Jul 17, 2016 | 06:30 PM
jacknk's Avatar
Will do, thanks.
Old Jul 23, 2016 | 07:44 PM
dlowings's Avatar
Just had the same issue with my 2005 ... Anytime the car was in drive it would beep.. Took it to jaguar and they ended up replacing the electric parking break switch in the center console... Never in a million years would I have guessed it was the parking break pull button.
http://www.ebay.com/itm/2003-2004-20...xSZvgE&vxp=mtr
Old Jul 23, 2016 | 09:30 PM
jacknk's Avatar
Will take a look, thanks.
Greggbhill
Jul 15, 2019 04:09 PM
o2manyfish
Apr 4, 2016 11:13 AM
Uncle Fishbits
Mar 24, 2016 06:20 PM
Jag Master
24
Mar 25, 2009 07:14 PM
Mar 3, 2007 11:37 AM
