Jaguar S Type 2000 3.0 V6
Old Apr 10, 2018 | 09:42 AM
ivicks's Avatar
Default Jaguar S Type 2000 3.0 V6
Hey all,
I changed ignition coils and plenum gaskets and it seems like the error code P0301 is solved, at least i hope, i have driven the car for 30 miles so far and the car seems to be running pretty well without any trembling at all.
The problem is that, along with the p0301 error code i had P0401 & P1573 code, after working on the car, P0301 and P1573 is gone! (I hope it wont return)
BUT NOW, ITS Still Showing P0401, P0420!!!!!!!!!!!
What did i miss?
Does anyone have any idea about what could be wrong here?
In case if it helps you, I still have to change engine oil, Does P0420 have to do anything with burnt engine oil?
Old Apr 10, 2018 | 10:22 AM
NBCat's Avatar
DTC P0420/P0430 means the catalyst is not performing properly.
In the case of P0420 (Bank 1 catalyst below threshold), the RH catalyst as viewed from the driving position has most likely been damaged due to misfire(s) causing unburned fuel to overheat the catalyst.
If the MIL was flashing during the misfire condition, the catalytic converter for Bank 1 needs to be replaced to eliminate P0420.
Old Apr 10, 2018 | 10:48 AM
ivicks's Avatar
Alright, thanks, just one question, what is MIL?
Old Apr 10, 2018 | 11:02 AM
joycesjag's Avatar
My Mother In Law was known to be a flasher in the 70's, crazy woman!
Malfunction Indicator Light
Old Apr 10, 2018 | 11:03 AM
ivicks's Avatar
Haha, got it,
thanks!
Old Apr 10, 2018 | 11:14 PM
ivicks's Avatar
Can I drive my car without fixing this codes for 300 miles on a trip??
Old Apr 11, 2018 | 08:46 AM
NBCat's Avatar
If there is a misfire situation and the Malfunction Indicator Light begins flashing, plan on replacing the catalytic converter upon your return.
Old Apr 12, 2018 | 08:56 AM
ivicks's Avatar
That helps, Thank you.
Old Apr 12, 2018 | 10:28 PM
Don B's Avatar
Hi ivicks,
P0401 indicates insufficient Exhaust Gas Recirculation flow in the "A" circuit. This is a Ford diagnostic trouble code (DTC) that is not implemented on V8 S-Types, but your 3.0L V6 is an upgraded version of Ford's excellent Duratec engine, so you probably need to check out your EGR valve and system.
Cheers,
Don
Rudisill
Nov 4, 2014 10:23 PM
jagosaurus
Dec 2, 2013 04:32 PM
WillyWheels
Jul 27, 2012 07:44 PM
thetruthc32
Oct 18, 2007 04:39 PM
Sultan
Aug 2, 2007 10:31 AM
