Jaguar S-Type Brakes Binding
Old Mar 6, 2017 | 07:56 AM
NinoGrimace's Avatar
Default Jaguar S-Type Brakes Binding
Hi All,
My Jaguar S-Type is a 2004 model, I am having a issue and when the car is in D or R, the car doesn't move unless I press the accelerator. When I release the accelerator the car seems to slow down by it self at a quick speed.
This has lead me to think that the breaks are binding and wanted to know if anyone knows what could be causing this. It has caused my ABS light to come on and force the car into limp mode (limp mode comes on and off)
Kind Regards,
Nino Grimace
Old Mar 6, 2017 | 08:04 AM
davidladewig's Avatar
You may have a stuck brake caliper. If you can get a light on the pads, check and see if they are all about the same. If one is real thin, start there and then have your abs unit checked.
Old Mar 6, 2017 | 11:55 AM
Ducmon's Avatar
You could also Jack the car up one wheel at a time and rotate the wheel. They should all move freely.
Old Mar 7, 2017 | 06:27 AM
CThomas's Avatar
Mine were dragging after changing the pads because I had put the left where the right goes and vice versa. The pad with the springs belongs on the inside.
Old Mar 7, 2017 | 06:57 AM
Thank you for your suggestions, I will try these over the week and let you know how it goes.
ecamiel
Nov 14, 2019 07:28 PM
Rpach10115
Oct 6, 2016 06:45 PM
scottpix
Oct 5, 2016 02:18 PM
Jul 31, 2012 01:29 PM
Dec 2, 2005 12:57 AM
