Jaguar Stype Recalls???
Heyy I'm having a issue with my car not getting enough power, so I took it to the Jaguar dealer and they said my transmission was fine. Here is the issue, when I take off its slow, once my car goes into second gear the speed picks up. So I did some research and came across this.
So I'm wondering is this my issue?? Have any of you experienced this issue? Your thoughts and ideas are appreciated, thanks in advance.
Item Affected: FUEL SYSTEM, GASOLINE
Date Announced: 6/23/2006
Description of Recall:
CERTAIN AFTERMARKET FUEL FILTERS SOLD UNDER THE PUROLATOR BRAND NAME, P/N F65277, SHIPPED FROM JANUARY 16 THROUGH JUNE 2, 2006, FOR USE ON THE ABOVE LISTED PASSENGER VEHICLES. DUE TO INCORRECT DESIGN, THE QUICK CONNECTORS MAY NOT FULLY SEAT WITH THE TUBE INTERFACE, EVEN THOUGH THE PERSON MAKING THE CONNECTION MAY BELIEVE THAT THE QUICK CONNECTOR IS FULLY ATTACHED.
Action Needed To Fix It:
UFI WILL NOTIFY OWNERS AND REPLACE THE FILTERS FREE OF CHARGE. THE RECALL BEGAN ON AUGUST 4, 2006. OWNERS MAY CONTACT UFI FILTERS USA AT 800-230-5876.
Find your local Jaguar Service Center.
This was on Jaguar S_TYPE Recalls - DealerRater but of course it's on tons of other sites.
I believe the recall had something to do with incorrect fitment of the filter possibly leading to a leak. Recalls are for safety purposes not substandard quality.
If the filter was the cause, the car would perform poorly in all gears not just first.
A filter installed in 2006 is probably due for replacement anyway.
