Just bought '05 s-type
Old Dec 2, 2014 | 03:48 PM
  #41
Dino V's Avatar
Originally Posted by Mikey
What did find about the speedo accuracy?
I am hoping to knock that out today. I'll report back on that. I was using the two 50 degree days we had here to inspect underneath and all that.
Thanks,
Dino
Old Dec 4, 2014 | 08:54 PM
  #42
Dino V's Avatar
Ok two things:
1. In test mode speed mph screen shows whatever the speed displayed on speedometer multiplied by 10. For example, 40 mph shows up as 400mph. Is this normal?
2. Here are the fuel readings in test mode at approx 1/4 fuel gauge mark:
Fuel driver-351
Fuel percent-64
Fuel filter 2-0
Fuel filter 1-139
Raw fuel 2-28
Raw fuel-131
Old Dec 4, 2014 | 09:59 PM
  #43
Mikey's Avatar
It might be 40.0 MPH. In any case it seems that there is no discrepancy between the digital and analogue displays. Next test is with a GPS.
Old Dec 5, 2014 | 02:09 AM
  #44
JagV8's Avatar
Mine is similar EXCEPT the dash speedo is consistently 5-10% higher (clearly software tweaks the values). I think this is to assist in complying with the law (which requires a speedo never to under-read).
Old Dec 5, 2014 | 08:30 AM
  #45
pab's Avatar
pab
Ha, I fixed that when I bought a set of XF wheels that came mounted with 245/45-18 tires. My speedo now reads 3-4mph low... :-)
Understeer is when you hit the wall with the front of the car
Oversteer is when you hit the wall with the rear of the car
Horsepower is how fast you hit the wall, and
Torque is how far you take the wall with you
Old Dec 5, 2014 | 09:34 AM
  #46
Mikey's Avatar
We're talking about analogue vs. digital indications only, not actual over-the-road speeds (yet).
It would be nice to find a way to tap into the tweaking done by the software as mentioned by JagV8. My digital is pretty much spot on when it comes to actual over-the-road speed but the analogue over indicates by about 5% even with brand new tires.
Old Dec 8, 2014 | 01:25 PM
  #47
Dino V's Avatar
Thanks Mikey. I'll be getting my hands on a gps system today so hopefully I'll have more to share tomorrow.
Old Dec 9, 2014 | 08:48 AM
  #48
Dino V's Avatar
Here's the fuel readings when I filled up this morning:
Fuel driver: 1345
Fuel %: 242
Fuel filter2: 0
Fuel filter1: 227
Raw fuel 2: 237
Raw fuel 1: 181
VS previous 1/4 tank readings:
Fuel driver: 351
Fuel %: 64
Fuel filter 2: 0
Fuel filter 1: 139
Raw fuel 2: 28
Raw fuel: 131
Old Jan 8, 2015 | 01:19 PM
  #49
Dino V's Avatar
Just an update for everyone. It appears that the speedo issue has resolved itself. I am thinking maybe due to the low miles and sitting, it just needed to be driven. Put about 1300 miles so far on it.
Old Jan 8, 2015 | 02:30 PM
  #50
tbird6's Avatar
I think Mikey was talking about using the GPS built into the factory navigation. Pretty handy because you can have the GPS speed on the nav screen at the same time as you are looking at the speedometer.
Old Jan 10, 2015 | 12:14 AM
  #51
kelbymorgan's Avatar
Originally Posted by Jon89
The key factor is that whatever ATF you choose must meet the Shell M1375.4 ATF specs. Lifeguard 6 (the "liquid gold" factory fill) does. Mercon SP does. Castrol Multi-Import did, but Castrol tech support now disavows its use as a substitute ATF in ZF applications, primarily for liability reasons. Owners here have used it with good results in the past, including Rick back in 2010. Others have used Pentosin, MobilOne, Wolf's Head, and RedLine over the years. In the UK, many report using MillerMatic fluids. Do your due diligence, make sure your ATF of choice meets the required specs, and follow the very cumbersome (and potentially dangerous) drain-and-fill procedures to the letter. If you screw it up, you could be sentencing your ZF to death with an underfilled transmission....
@Jon89, I recently filled my ZF. I believe we got in about 7 quarts. what is the best way to check the fluid level?
Old Jan 10, 2015 | 03:27 AM
  #52
JagV8's Avatar
There's a sticky about it. You need it at the right temp, engine running, car level, and the right amount coming out of fill hole.
Old Jan 10, 2015 | 07:14 AM
  #53
Jon89's Avatar
Bingo. It's a very cumbersome procedure. Make sure whoever checks the fluid level fully understands the process, otherwise you'll be doing more harm than good. And be prepared to add more fluid if needed....
Old Feb 16, 2015 | 01:31 PM
  #54
Dino V's Avatar
So it's been 3 months and about 3k miles of ownership (just hit 48k miles). I must say that I am enjoying it more than I thought I would (other cars are sports cars and it's been about 2 years since my last luxury car). With brand new Blizzaks this car has done phenomenal in even the freak blizzards we had this year.
Only minor nuisance are "the lurch" and fuel gauge not accurately reading entire tank.
Old Feb 16, 2015 | 10:20 PM
  #55
Warspite's Avatar
I love the idea of updating the wheel sets of older models with ones from top of the line current ones...OEM for sure. Did that with an Infiniti Q45...adding 350Z wheels. Caddy Seville? Used chrome STS wheels. The 2002 STs look fine...but the XF ones do have appeal. When it's time to replace the tires, it might be time to score a package deal on XF wheels and tires. I assume the bolt pattern is the same...
Old Feb 17, 2015 | 09:06 AM
  #56
SonnyJag's Avatar
Originally Posted by tony1963
I enjoy my 01 S Type 3.0. It is not near the car of my Mercedes, but interesting to drive around. Once you do the maintenance and take care of the frequently identified challenges, you're good to go.
Mine has the Ford 5-speed 5R55N automatic, yours has the more troublesome 6-speed ZF.
I also own a 01 S Type 3.0. It's Roman Bronze with barely 42k miles on it. I'm just wondering which "frequently identified challenges" you're referring to.
I've had it maintained meticulously by Jag dealerships and a private certified Jag tech.. Literally the only "issue" if you wanna call it that was a driver's side window motor that had to be replaced and was.
I'm actually getting ready to sell it shortly but I would feel awful knowing some component of the car is a ticking time bomb. Frankly, I would have to replace the part now before I sold it, just out of good faith. Any insight would be much appreciated.
Old Feb 17, 2015 | 10:06 AM
  #57
Warspite's Avatar
Don't feel bad - my driver-side window motor went out at 36,500 miles. 500 miles AFTER the warranty expired. Coolant recovery tank, and leading hoses are a high-failure item.
The 4.0 has an Achilles Heel - plastic timing chain tensioners - in 2002 and earlier S-Types, but not the 3.0.
Old Feb 18, 2015 | 03:03 PM
  #58
Dino V's Avatar
And Jaguar has some really nice OEM wheels. I am going to look more seriously once spring hits.
Old Feb 18, 2015 | 03:12 PM
  #59
TonyX's Avatar
... When it's time to replace the tires, it might be time to score a package deal on XF wheels and tires. I assume the bolt pattern is the same...
I can vouch that 18" XF wheels and tires work well on 2005 SType. You will get wider stance due to lower offset and wider tires but it looks very nice.
Old Feb 19, 2015 | 08:24 AM
  #60
pab's Avatar
pab
Here is a definitive list of OEM wheels that will fit an S-Type:
Jaguar - Vehicle Bolt Pattern Reference
(Jaguar _ Vehicle Bolt Pattern Reference)
On these pages you can find Jaguar vehicles Bolt Pattern and Offset. This will help you in determining High or Low offset and bolt patterns of your vehicle.
Discounted Wheel Warehouse has provided this information for its customers to provide the very best service to our customers. We offer a large selection of Jaguar Wheels and Jaguar Rims also Custom wheels, Car Rims, and Truck Rims so please enjoy the web site and choose your next set of Custom Wheels from Discounted Wheel Warehouse!
YEAR MAKE MODEL COMMENTS
2000 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2001 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2002 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2003 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2004 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2005 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2006 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2007 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2008 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2009 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2009 Jaguar XF 5 lug 4.25 inch or 108mm High Positive Offset
2010 Jaguar XF 5 lug 4.25 inch or 108mm High Positive Offset
2011 Jaguar XF 5 lug 4.25 inch or 108mm High Positive Offset
2012 Jaguar XF 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XF 5 lug 4.25 inch or 108mm High Positive Offset
2014 Jaguar XF 5 lug 4.25 inch or 108mm High Positive Offset
2010 Jaguar XJ 5 lug 4.25 inch or 108mm High Positive Offset
2011 Jaguar XJ 5 lug 4.25 inch or 108mm High Positive Offset
2012 Jaguar XJ 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XJ 5 lug 4.25 inch or 108mm High Positive Offset
2014 Jaguar XJ 5 lug 4.25 inch or 108mm High Positive Offset
2010 Jaguar XJ SS Super 5 lug 4.25 inch or 108mm High Positive Offset
2011 Jaguar XJ SS Super 5 lug 4.25 inch or 108mm High Positive Offset
2012 Jaguar XJ SS Super 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XJ SS Super 5 lug 4.25 inch or 108mm High Positive Offset
2014 Jaguar XJ SS Super 5 lug 4.25 inch or 108mm High Positive Offset
2004 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2005 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2006 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2007 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2008 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2009 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2010 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2011 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2012 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2004 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2005 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2006 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2007 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2008 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2009 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2010 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2012 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2014 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2012 Jaguar XKR 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XKR 5 lug 4.25 inch or 108mm High Positive Offset
2014 Jaguar XKR 5 lug 4.25 inch or 108mm High Positive Offset
2011 Jaguar XKR-S 5 lug 4.25 inch or 108mm High Positive Offset
2012 Jaguar XKR-S 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XKR-S 5 lug 4.25 inch or 108mm High Positive Offset
2014 Jaguar XKR-S 5 lug 4.25 inch or 108mm High Positive Offset
2002 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2003 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2004 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2005 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2006 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2007 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2008 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2009 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
My karma just ran over your dogma
'08 Jaguar S-Type 4.2
