Lean codes with no vacuum leak update.
Old Jan 8, 2024 | 12:38 AM
deankellscjag's Avatar
Default Lean codes with no vacuum leak update.
Codes P0171/174. Engine runs flawless. Have smoke tested and confirmed there is no vacuum leaks. Checked over the brake booster line and supercharger fitting those are all fine.
Now my drivers side catalytic converter is rattling. 172k miles it’s expected they go bad. Unfortunately I live in California and need to get the car smogged. What are my options ? No code for the cat yet I wonder if I can just dig out what’s rattling and put them back on. Is it possible that the cats are causing the 171/174 code ? Would 90 degree defoulers fix this? Thanks for the help guys
Old Jan 8, 2024 | 01:41 AM
JagV8's Avatar
Do the incredibly simple test for whether it's a leak: is any trim high at idle & drops when revved?
Old Jan 8, 2024 | 04:21 PM
clubairth1's Avatar
Community Influencer
Maybe the ratting cat is just a heat shield?
Easy to rule out on a lift.
NYCJAG2006
Dec 19, 2023 04:08 PM
David N. Warner
Jul 8, 2023 10:01 AM
wordman
Feb 18, 2020 09:38 PM
squish
Sep 24, 2010 09:04 PM
kandA
Mar 11, 2008 06:43 PM
