LED Conversion - Dim Afterglow
Old Feb 8, 2022 | 03:43 PM
LLLA's Avatar
Lightbulb LED Conversion - Dim Afterglow
Hi All-
So I'm hoping to do an LED retrofit on all bulbs in my 2002 S-Type (headlights and fogs included). I started with the reverse lights, but quickly found that they stay on even after they have been switched off. I dug around the site and found a thread saying this is normal (see link ahead); Warspite mentioned potentially wiring in resistors to help alleviate this issue. (Link to Thread) (Didn't want to dig up a super old thread) I have yet to find LED bulbs which include resistors which would work with our setup.
Interestingly, I was able to replace the license plate bulb with LEDs without issue.
I have sourced a second set of Left/Right bulb "trays" if you will? (See picture below) I was curious if anyone was ever able to do this? I've seen others mention issues with parking lights and blinkers; haven't gotten that far yet.
Thanks in advance!
Old Feb 8, 2022 | 05:38 PM
JagV8's Avatar
You may need ones rather weirdly called CANBUS.
Old Feb 9, 2022 | 03:35 AM
M-e-l-l-o-w's Avatar
The main thing you need to know is that the rear lights work on a switched earth not a switched live.
What looks like an earth track on the light cluster and is connected to the outside of the lamps is actualy a +12v live feed not an earth.
The glow you get is the result of a back feed through the rear electronics module via the turn lamp.
Mellow
Old Feb 9, 2022 | 04:37 AM
JagV8's Avatar
as shown by the Electrical Guide (free download)
Old Feb 9, 2022 | 06:34 AM
ControlIssues's Avatar
+1 on getting CANBUS leds. I just did Lasfit colored leds for my front and rear markers and side repeaters. They work perfect for not throwing a code or blinking fast. You need to match the lamp color to the lens color. Its important. I went into the front parking lamps but removed them. The color and brightness looked wrong to me.
I did the whole interior long ago so I could see better. That came out nice.
Dan219
E type ( XK-E )
Nov 15, 2021 07:59 AM
Jdrasp
May 5, 2018 08:11 AM
flyrr100
Nov 3, 2014 01:54 PM
Frog
Feb 29, 2012 12:47 AM
JagXType620
Jul 29, 2009 05:24 PM
