Left tail lamp failure
Old Sep 11, 2018 | 09:50 PM
Ajh183's Avatar
Default Left tail lamp failure
Thanks for the approval:
heres my issue...i have a 2006 jaguar S Type. It has been flawless until now. I've gotten the left tail lamp failure message and left brake light failure message. I've change bulbs, checked fuses, changed socket panel, tried just about everything. I get the message to clear until i turn on the lights or hit the brake pedal and the message returns. I did notice today that when i tapped the lens the bulbs came back on.. Are the bulbs suppose to be tightly seated or once in they can wiggle a bit? I gotten and tried just about every suggestion to no success. Ive seen many posts throughout sites where owners have experienced this issue. Inspection time and i need this fixed. Thanks to anymore suggestions.
Old Sep 12, 2018 | 06:00 AM
wydopnthrtl's Avatar
If they come back on by tapping you have some kind of corrosion or looseness. Remove the bulbs and clean the connections w/a strong cleaner and Q tip. (I'd use rubbing alcohol). If that doesn't work look for a local ground that is loose or corroded
Old Sep 12, 2018 | 07:04 AM
Ajh183's Avatar
thanks...will try that today.
Old Sep 12, 2018 | 08:24 AM
Have you tried swapping the bulbs from side to side to see if the fault follows?
Don't forget to post an intro in the new members section.
Old Sep 12, 2018 | 09:06 AM
Ajh183's Avatar
yes and thank you for the reply.
Old Sep 21, 2018 | 02:46 AM
M-e-l-l-o-w's Avatar
This may sound daft and you have probably already checked this, but you need to make sure you have the correct replacement lamps. There are different lamps with different pin lug locations in the metal cap. If you get the wrong ones they may go in, with some effort, but they will not work as they should.
Old Sep 21, 2018 | 05:11 AM
Ajh183's Avatar
  1. Th@nks for the reply. We figured it out. Was a simple fuse in the trunk after all.
Old Sep 21, 2018 | 08:32 AM
S-Type Owner's Avatar
Which fuse number was the culprit..? Having the information for the fix available here will save the next owner with the problem some time and aggravation,
Thanks!
JR
cityboy
Jul 7, 2018 05:14 PM
aratnam
Aug 18, 2016 12:39 PM
Sonspit
Oct 5, 2014 07:22 AM
pt80chip
Oct 24, 2013 07:54 PM
Darrel Walters
Feb 7, 2013 06:56 PM
