Lock out of Boot (Trunk)!
Old Nov 17, 2013 | 10:13 AM
plums's Avatar
Originally Posted by police666
The release catches are in the boot, if the is no battery connected, will powering it from the wheel arch point work?
yes because the wheel arch point is in common with the power distribution bus
Old Nov 17, 2013 | 04:22 PM
doodlebomber's Avatar
Thank you all so much for all your help
I managed to get into the boot today - with a bit of effort
If it helps anyone - this is what I did:
I took the bottom of the rear seat out - remove two bolsters and then undid the two catches at the front of the seat.
Released the bottom of the upright seat by undoing four nuts (one each end and two by the bottom of the arm rest). This gave me about 5 -6 inches of access at the bottom of the seat, as the top of the seat back is still attached.
I used a light to see into the boot and reached in using an implement to undo the rear seat release catch (I tried several implements before I got one to work - I eventually used a 17mm spanner tied securely to a long paint roller handle, but any 2ft stick or handle would do). The 17mm spanner was perfect for pushing the catch open. I have a photo of my special tool if anyone is interested.
On releasing the catch I had easy access to the boot, I undid the 2nd catch on the other side of the boot to get full access.
I was then able to reattach the battery terminal and open the boot using my normal key fob
(Likewise, if the battery had been dead, I could have charged it / changed it).
I hope this post helps others who have boot problems or lock their keys in the boot!!!
Old Nov 17, 2013 | 05:44 PM
biffo17's Avatar
and sort the lock or key to open boot lol
Old Nov 17, 2013 | 07:16 PM
joycesjag's Avatar
I am interested, and a photo or 6 are always a sure fire help too.
dsnyder586
Dec 29, 2024 07:39 PM
BadKat174
May 26, 2023 12:29 AM
XJsc-guy
Nov 23, 2015 01:56 PM
Ragn0r
Sep 19, 2015 08:39 AM
speacock
Sep 10, 2015 12:14 AM
