Marker license and tail lights
Old May 17, 2012 | 01:12 AM
Gilly's Avatar
Unhappy Marker license and tail lights
HI All:
I got a weird problem on by 2005 s-type 3.0 jag.
Turned the car off tonite and went to leave. The chime remained on as is the lights were on? Made sure all switches were either on auto or off. Same thing.
Got out and sure enough, the side front & rear marker lites are on as well as the tail lites. As if the switch on the single lite leave was turned on. I get no warning other then the chime. I pulled relays and nothing. Everything seems to work just fine. no switches are on; however I can not get the lights to go off with out pulling the battery cable.
Any ideas ?
Gil
Old May 18, 2012 | 08:33 AM
JagV8's Avatar
Common(ish) things:
1. water/damp in trunk (boot) - remove spare and check very carefully
2. faulty module(s) - usually GECM/RECM
3. corroded wiring - needs front bumper off to check harness thoroughly and if not there then in the wheel arches (wells)
kj07xk
Dec 18, 2025 10:56 AM
H20boy
Dec 24, 2024 03:23 PM
SCMike
Sep 22, 2015 07:34 PM
motorhead69
Sep 9, 2015 10:04 AM
raffoulig
Sep 8, 2015 01:56 AM
