Mina Hyper bulbs impression
Hi,
For quite some time I have been looking for bulbs (High beam and fog) that come closest to matching the HID's on the str.., outside of an hid fog conversion. I had already installed led front markers which are awesome. I had gone through almost all supposed "white' 4300-5000k bulbs and was never pleased. I finally went with the Mina hyper bulbs, which initially i had avoided because of the price....well, I have to say these are the real deal.
As you can see in the pics..both the highs and the fogs are extremely close to the HID..in fact in person, almost imperceptable.
also if any one is interested.. I have a pair of the fogs..H1...these are 60 bucks plus shipping @ Mina...ill do 45 bucks including priority ship ..just pm me.
CIMG0048.jpg?t=1294238381
CIMG0046.jpg?t=1294238402
I went with the HIR bulbs. A bit hard to find because the technology is not that well known. Really like them in the high beams on my 2005 STR!! Found one small mention on another Jaguar board and only Toshiba makes the real HIR bulbs. These are performance lights and are not for looks/style!!
Take a look;
http://www.finemotoring.com/index.htm
Take a look;
Riski, do an HID conversion. Exact match, and tons more useable light. It's about the same price as these overpriced halogen bulbs. Let me know if you need help / advice. You'll thank me later.
George
George
Take a look;
Take a look;
Do you have these installed?
Are these what you ordered? I don't see the S Type lights there.
http://www.minagallery.com/jagxp/Jag...s-upgrades.htm
Hi,
yes those are them..i dont know what s type uses, but str are 9005 high beam and H1 fog... email Chris @ mina for your application and if you need h1 I have a new set
Hmm...about the same price??...if so i would do it but I cant see a quality hd conversion coming in for 50 bucks so please...inform me!!
Take a look;
Take a look;
hmm. curious about these since they make this statement"
These bulbs produce white light, rated at 3600 Kelvin color temp, slightly whiter than the 3250K stock halogen bulbs.
3600 is far from white...these would look very yellow against HID..as hid is, in general 4350k stock from most manufacturers. The true white k sectrum is 4500-5000k..The hyper bulbs are 5000k @ 110w..not 55w which is why the throw the whiter light
just my observation
well...live and learn...might have to check these out then !!
just my observation
just my observation
There's no point in using an inferior older technology that's trying to imitate modern technology while sacrificing light output, or putting an inordinate amount of draw on the electrical system when the cost of what you're trying to imitate is now the same. Go HID in your fogs, more light output AND only a 35w draw on your electrical system.
I second the recommendation for www.ddmtuning.com Jim Powell is a good guy, I know him personally, but check the shipping dates, sometimes they get swamped and you have to wait a bit.
For the fog application, I would go with their "slim" ballasts for 2 reasons. 1, they are physically smaller and therefore easier to mount, 2 they are sealed in epoxy (as opposed to a metal housing bolted shut on the fullsize), so they are much more resilient to water.
Anyone who needs help installing one of these kits, PM me.
George
ooohhh ...awesome...guess i have a project.......curious now as to why mina would sell these bulbs if they are not safe, and now looking again, it states these are 130w bulbs!!
Another nice thing about DDM is the variety of temps you can get the bulbs in. The wiring can be a bit tricky, but if you wrench on your own car you should be able to figure it out.
George
Are you comfortable taking the front of the belly pan off?
Replacing bulbs?
Drilling a hole with a hole saw?
Splicing a couple wires?
Mounting a box?
That's basically all that's involved...
How long an how easy all depends on how fast you work, and how comfortable you are doing these things.
It's not difficult, or particularly complicated and I can walk anyone through it.
George
Replacing bulbs?
Mounting a box?
George
Pushing_Tin;
Yes I have the HIR bulbs in the high beams. Very nice light output. Wavelength is different from light intensity. That's the improvement. They even tested the blue looking bulbs and they have a very reduced light output to produce the desired color when compared to the HIR technology. Compared to my factory HID lights the HIR bulbs look pretty similar but it will vary with the individual.
Another issue is the reflector design. Aftermarket HID's do not use the proper reflector so they fall short when compared to the factory HID's. The nice thing about the HIR bulbs is they have the filament in the stock location so the factory reflector is still geometrically correct for these bulbs.
