misfire problem 4.0 V8
Old Jan 15, 2012 | 01:02 AM
electropleb's Avatar
Default misfire problem 4.0 V8
its a v8 4.0 S-Type.
ok, little history, I used to have a misfire on number 3 and 8, that was fixed by changing all the spark-pluggs and changing 2 coils.
now I have a misfire on 2 and it happens when your going between 45 mph and 55. when its idling its fine or above 55 its fine, its always after 45mph
what do you think?
thanks for your help
Old Jan 15, 2012 | 09:06 AM
nasdaq6's Avatar
sounds like more coil pack issues, when one goes they all start to go i had the same issue. Also when i was having missfire issues i changed my mass air flow sensor. But check all your coil packs first
Old Jan 15, 2012 | 09:50 AM
bfsgross's Avatar
Good advice.
Old Jan 15, 2012 | 11:33 AM
Jon89's Avatar
Jaguar struggled with S-Type coil suppliers in the early years (1999-2002). Several different designs were tried, and the coils were somewhat better in the 2003-2004 models. By the 2005 models, the coils were apparently up to average industry standards. Still not great, but at least better than a poke in the eye with a sharp stick....
Old Jan 15, 2012 | 05:48 PM
bfsgross's Avatar
Lincoln LS uses the same coil.
Old Jan 15, 2012 | 06:47 PM
Thank you so much everyone, that helps a lot.
Thank you again
Dicque
Sep 19, 2015 12:53 PM
corysansburn
Sep 10, 2015 06:15 AM
mrplow58
Sep 9, 2015 11:27 AM
Dicque
Sep 4, 2015 12:50 PM
Bowman
Sep 3, 2015 03:17 PM
