Misfiring & stuttering 3.0 V6
Old Nov 29, 2012 | 01:08 PM
Stanners's Avatar
Default Misfiring & stuttering 3.0 V6
Right then..
Got my S type 3.0 V6 manual,80K on the clock,year 1999
Has a misfiring problem which is intermittent. The car was parked up for 7 months and he said it was running fine before with no problem and now its on the road it's misfiring. Am I right in saying its a common problem to be coilpacks and easier to replace all 6 plugs and coilpacks? OR what would be the chances be for it to be the MAF sensor? Or is coilpacks the more likely cause?! I've had a fault code reader plugged in and nothing comes up neither is an engine management light on.
Opinions would be greatly appreciated.
Many thanks
Matt
Old Nov 29, 2012 | 01:28 PM
JagV8's Avatar
MAF is last suspect at this stage.
Coils or even more likely an air leak - try Search with
hose elbow
hose leak
and so on. Quite cheap to fix
Check fuel trims to confirm.
aode06
Jul 28, 2023 02:26 PM
Newark Nj Gang
Oct 2, 2015 02:39 PM
Roman fellow
Sep 26, 2015 10:19 AM
reb1999
Sep 26, 2015 08:41 AM
