Mr. Greene
Old 06-01-2017, 12:30 PM
LeeG63's Avatar
Default Mr. Greene
I have 2003 S-Type 3.0 and I am receiving a restricted performance on the dash.
I had a diagnostic test done on the car. The codes that came up were Cyl 5 was misfiring do to bad ignition coil.
Knock Sensor Bank 2
P013/p016
PO1111
what does these codes reference
Old 06-01-2017, 01:33 PM
GGG is offline
Received 16,827 Likes on 12,179 Posts
Welcome to the forum Mr. Greene,
I've moved your question from X300 to S-Type forum. Members here with the same model will be able to help.
Old 06-01-2017, 01:37 PM
JagV8's Avatar
Received 4,489 Likes on 3,906 Posts
There are no codes P013/p016 so please correct them.
It's not going to run OK if there's a KS fault.
I can't recall if cyl 5 is awkward access - if not, swap/replace the coil with a good one (don't buy cheap).
Old 06-01-2017, 09:58 PM
aholbro1's Avatar
Received 1,642 Likes on 1,068 Posts
1, 3, and 5 are a bit of a bitter ex-wife to change....under the upper intake manifold. 2, 4, and 6 are easier.
Old 06-01-2017, 10:27 PM
joycesjag's Avatar
Received 1,695 Likes on 1,210 Posts
Originally Posted by LeeG63
P013/p016
PO1111
As mentioned above absolutely nothing. BUT....
Get the correct codes posted. As brother "aholbro" (still slays me to type that after all these years ) suggested.
You are looking at a possible failed coil under the intake manifold (aka plenum). more than likely you will crack a couple vital vacuum lines trying to get to that particular COP (Coil Over Plug).
Save yourself the headaches. Purchase only OEM COPs, or at least 2. Replace #3 and #5 when you get to them. Number 1 COP is replaceable without removing plenum. Also, I recommend that you replace the spark plugs on all cylinders if you haven't yet. Another important tid bit of info... Purchase a valve cover gasket set from FelPro, along with plenum (some call them upper intake) gaskets AND lower intake gaskets while you are into a vehicle that is 14 years old.
Look at the link below, it covers all vacuum lines that you are most likely going to crack upon replacing #5 COP. Drop a couple extra bucks and do the job correctly the first time! Don't forget the IMT orings!
This post alone would cost a Jag owner a few hundred $.
https://www.jaguarforums.com/forum/s...ics-faq-52720/
Just to add I know what I am typing about, below is another epic link that I saved a "green" college kid thousnadssssss of dollars on his 2003, 3.0 years ago:
https://www.jaguarforums.com/forum/s...tenance-49309/
you are welcome in advance.
aholbro1 (06-01-2017)
Old 06-01-2017, 11:16 PM
aholbro1's Avatar
Err....Rick? Which side does he find #7 on in his 3.0L?
Old 06-01-2017, 11:34 PM
joycesjag's Avatar
Hee hee drunkin' stuper maybe
I will go back and correct cylinder order
MarkN
12-23-2016 12:21 AM
Samantha Larson
11-06-2016 05:42 AM
08-16-2013 07:48 PM
ancientsanskrit
06-30-2007 05:52 PM
Quick Reply: Mr. Greene
