Mud flaps
Old Aug 1, 2022 | 01:15 PM
fromtulsa's Avatar
Default Mud flaps
I have this right rear mud flap on my 2001 S-Type 4.0 and I've been looking for the matching left rear mud flap. I've searched salvage vehicles and online, but I've never seen another one. Is it OEM? I've read that they're more for aerodynamics, since they're positioned in front of the tire. Behind the front tires, it looks like I could also put mud flaps, but have never seen these as OEM either. I prefer OEM, but would look at alternatives. Thanks for your help.
Old Aug 2, 2022 | 06:26 AM
neilr's Avatar
I think you might be looking for XR810616 and XR810617.
I believe that some form of deflector was placed before wheels on all cars to direct salt water away from the brake disc as this was somehow glazing them.
Old Aug 2, 2022 | 12:45 PM
fromtulsa's Avatar
Thanks, neilr. That looks like the right part number. They must not have sold very many, since they are hard to find. Do you think the front part numbers would be the same? I doubt it, because of their reversed (back of tire, instead of front of tire) placement.
Old Aug 2, 2022 | 01:10 PM
neilr's Avatar
They are called spoilers and were standard on the pre-facelift cars (199-2002)
https://parts.jaguarlandroverclassic.../brand/jaguar/
Mudflaps are similar but not the same
The front spoiler was just a flap IIRC.
Old Aug 3, 2022 | 10:25 AM
M-e-l-l-o-w's Avatar
XR810616 is the right hand side rear item.
These are easy to obtain as they are still available from Jaguar, as is the left hand item.
They cost £60.66.
They were only fitted up to VIN number M45255 that is the 2000 and 2001 model year cars.
Here is a link to the official Jaguar parts web page with this item:
Mellow
Old Aug 3, 2022 | 09:20 PM
Rober2's Avatar
thank you for this. I did not know I needed them. Have to rush to the wreckers as I think the 01 there have all rear ones still intact.
Old Aug 7, 2022 | 06:38 PM
Rober2's Avatar
so, how many flaps/spoilers should an 01 S-type have? 2 in-front (positioned after the tyres) and 4 rears (positioned before and after the tyres)? I saw a photo with this config
Old Aug 10, 2022 | 12:55 AM
neilr's Avatar
The true mud flaps, positioned behind the wheels were optional.
The "spoilers" or similar extensions in front of the wheels were standard.
Old Aug 10, 2022 | 02:18 PM
cats4.2's Avatar
The first picture is the standard spoiler flap in front of the front wheel. The second and third pictures show the true mudflaps. (the ones with the cat face, behind the front and rear tires) I ordered these separately for my car. They are pretty useful and look good, too.
Old Aug 10, 2022 | 05:05 PM
Rober2's Avatar
Thank you for the confirmation. I want those too.
Old Aug 11, 2022 | 02:57 AM
neilr's Avatar
Have a look for these:
Front: XR828879
Rear: XR82888
Personally, I would look for new ones simply because after some years they go brittle and can fail along the thinnest parts of the moulding. These flapping about against the body isn't a nice feeling or good for the paintwork! If you look around and are lucky, they can be found for not too much.
Old Aug 11, 2022 | 03:54 PM
Rober2's Avatar
Front: XR828879
Rear: XR82888
Thank you and I hear you. Seems that there are new ones available, will get those. Cheers
Old Aug 11, 2022 | 04:18 PM
clubairth1's Avatar
Community Influencer
Sometimes they are also called Aero-Tabs.
The idea is to push the air away from the spinning tires. Helps reduce aerodynamic drag to a small degree.
Pretty common on most cars since around 2000 or so.
Old Aug 12, 2022 | 02:31 AM
Rober2's Avatar
Thanks, aerodynamics in a Jag? over-reach?
LnrB
Jun 6, 2022 09:04 AM
Reaxions
May 10, 2022 10:52 PM
MajorTom
Jun 26, 2021 01:12 PM
jagtoes
Jun 2, 2015 02:33 AM
exexpat
May 5, 2011 01:45 PM
