My A/C Sucks!!
Old Oct 7, 2008 | 05:36 PM
stdjrm17's Avatar
Default My A/C Sucks!!
I have a 2004 S-Type 3.0 and for some reason the A/C is no longer blowing cold air. I went and bought one of those cans that you can use to refill the free-on but my problem is I don't know where the valve is to hook it up. Does anyone know?
Old Oct 7, 2008 | 05:57 PM
racerx82's Avatar
Default RE: My A/C Sucks!!
yes, it's under the hood .
Old Oct 7, 2008 | 06:14 PM
H20boy's Avatar
If its got a leak, no amount of refill will give you back your cold A/C. Best bet is to suck it up, save a weeks worth of chili's and bennigan's meals, and get to any ol' mechanic who can leak test your system, fix it, then give you a full charge of freon. Anything else is just wasting your dollars and killing our ozone. (unless it's CFC free!) sorry for dismal outlook, but its the sad truth. On the bright side, it shouldn't leak on you again, for at least another summer .
Old Oct 7, 2008 | 06:19 PM
wally509's Avatar
I have a 2005 3.0 (production date of 2/04) and there isan A/C connectionin the driver's side wheel well. I noticed it while doing a brake job on the car. Hope this helps.
Old Oct 7, 2008 | 09:06 PM
racerx82's Avatar
Is it the high side or low side???
Old Oct 7, 2008 | 10:12 PM
Brutal's Avatar
that low side, and yes you can add, and see how fast it goes back down, but you dont have anyway to know if its empty or low and youll either still be under charged or over charged, the system holds 1.8#s when empty. but then again, one of the most common failures on that system is the evap temp sensor in the drivers side of the hvac case. they get outta wack and make the system think theres are problem like evap freezup, or overheating and shuts compressor off, next most common is leakage at the compressor(look for green oil drips on the compressor)
Old Oct 7, 2008 | 10:46 PM
racerx82's Avatar
BTW, A/c doesn't suck..it blows....just an fyi...
Old Oct 8, 2008 | 08:00 AM
Brutal's Avatar
ORIGINAL: racerx82
no the blower blows Mr drinky drink
Old Oct 8, 2008 | 08:17 AM
wally509's Avatar
BRUTAL,
That temp sensor sounds like an expensive job as I would assume the whole dash need to come out to get to it. Any thoughts?
Later,
Wally
Old Oct 8, 2008 | 09:34 AM
racerx82's Avatar
I stand corrected...thanks mate!
Old Oct 8, 2008 | 11:25 AM
Brutal's Avatar
ORIGINAL: wally509
BRUTAL,
Later,
Wally
NO ONCE YOU GET YOURSELF UPSIDE DOWN UNDER THE DASH YOU SLIP A SMALL SCREWDRIVER BETWEEN THE CASE AND SENSOR AND POP IT OUT, DISC CONNECTOR AND PUT THE NEW ONE IN. TAKES A WHOLE MINUTE
Old Oct 8, 2008 | 12:04 PM
KAZsam's Avatar
ORIGINAL: racerx82
that was cold but, technically correct.
Old Oct 8, 2008 | 12:21 PM
JagXV6's Avatar
The low side of an AC system is often called the
"suction" side. So technicaly all of our AC systems
'suck'.
Old Oct 8, 2008 | 12:23 PM
KAZsam's Avatar
Got to leave this thread know all this talk about sucking has got me willie winkin
Old Oct 8, 2008 | 12:53 PM
KAZsam's Avatar
I know Marcus I cant open pictures on this computer. All the posts ive read I had to sprinkle cold water on myself. Wait till I get home.
Old Oct 8, 2008 | 01:08 PM
harounq21's Avatar
I need the A/C to work. I am starting to sweat.
Maaden
General Tech Help
Sep 30, 2015 09:15 AM
dan102877
Sep 29, 2015 06:47 PM
oldjaglover
Sep 29, 2015 03:27 PM
42Ajd
Sep 26, 2015 07:04 PM
