My Power Lock Went Out...
Old Dec 10, 2010 | 07:42 PM
Cream's Avatar
Unhappy My Power Lock Went Out...
(s-type 2005)
Today I noticed my driver side rear door power lock went out :/
I can lock/unlock my door manually but not with the key remote or power button..
all the other 3 doors work fine
Ima take a look at it tomorrow and remove the door panel
Old Dec 10, 2010 | 09:51 PM
joycesjag's Avatar
Cream, ours did the same thing on Weds., I figured I would grab a cold 1 or 12 tomorrow evening and figure it out. Same door.
Old Dec 11, 2010 | 05:19 AM
JOsworth's Avatar
Two things tend to go wrong with power locks. Either a part in the linkage from the cylinder to the actual mechanical lock goes bad, or the actualtor goes bad. Most of the time it is just a stuck cylinder and all you need to do is take it apart and clean it up real good.
Good luck with it.... Just so you know what your getting into here is the parts schematic of the rear door.
Old Dec 11, 2010 | 06:00 AM
joycesjag's Avatar
thanks Jeff, I was going to rip into it blind.
Old Dec 11, 2010 | 10:28 AM
That's the spirit, there's nothing like a challenge.
Old Dec 11, 2010 | 10:05 PM
joycesjag's Avatar
so much for spirit, I got invovled in some poker games tonight and I said *&^% it tonight. Hopefully cream will let us know how it went.
Old Dec 15, 2010 | 12:11 AM
Cream's Avatar
Appreciate the help guys.. I havent had time to take a look at it, hopefully tomorrow if not this weekend ill remove that door panel & check it out :/
as soon as I do ill post an update!
Old Jun 8, 2011 | 12:27 AM
smkjunior's Avatar
same here. I got an exactly same problem, but mine is about both rear doors. Front doors are fine. I can hear some motor sound from the rear doors although they don't work.
Old Jun 8, 2011 | 09:02 AM
motorcarman's Avatar
What is it with the left rear doors???? I have a 2005 S-Type in my shop with a dead LR latch. I have the rear seat bottom out and the door panel removed and now to try to get the latch released (or broken into bits until the door opens).
bob gauff
Old Jun 8, 2011 | 09:39 PM
smkjunior's Avatar
I have 05 S-type too. Same here. I removed the rear doors' panel and now I try to fix it with lube spray. Still not working.
BadKat174
May 26, 2023 12:29 AM
XJsc-guy
Nov 23, 2015 01:56 PM
Ipc838
Sep 13, 2015 03:27 PM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
jagent
Sep 12, 2015 09:10 AM
