Need help 2003 S Type inserting the side rear replacement window
Old Aug 27, 2023 | 01:25 PM
ldrny's Avatar
Default Need help 2003 S Type inserting the side rear replacement window
I’m having no luck inserting the side rear replacement window on my 2003 S Type. Any tips?
Old Aug 27, 2023 | 06:12 PM
Peter_of_Australia's Avatar
It's not a big deal at all. I need more details, what your problem is. I just did it on my X-Type. Also: Front or rear door window?
In short: remove door trim (some screws - there are probably only 3 - are hidden underneath plastic covers.
park window approx. 10-15cm below top, loosen the 2 window bolts below, remove inner and outer window lip, pull out the glass via the outside. And reverse back in.
I think I might have mentioned something about getting the window in and out, but not in much detail, as it is really easy, in my thread:
https://www.jaguarforums.com/forum/x...x-type-271920/
Just don't drop the window-glass and don't tighten the 2 window bolts too tight (it would break the glass) and make sure the glass sits in the rubber correctly on the bottom.
Old Aug 28, 2023 | 09:41 AM
clubairth1's Avatar
Community Influencer
I think we are talking past each other here?
Are you talking about the small fixed window in the back door? Or the window that has a regulator that most of these posts are about?
Maybe a picture would help?
Old Aug 28, 2023 | 12:30 PM
ldrny's Avatar
Hi again. The problem is that I cannot slide the window into the door frame no matter which angle I attempt. I tried front corner first, rear corner first, from the inside of the door, from the outside. I just cannot get it into the door. I removed the door panel and the inside weather stripping from the window and still can't seem to get it to slide in. Thanks.
Old Aug 28, 2023 | 04:40 PM
I assume you have removed the inner and outer top lips (seals) of the door frame? So it is the rear passenger door (either I over read the word "rear", or you put that word into your question afterwards...). Well, I have not played with the rear windows yet, But if you got it out, you should get it in - from top down coming from the outside.
Old Aug 28, 2023 | 06:34 PM
ldrny's Avatar
I got it! Thanks so much. Any tricks for getting the rubber weather stripping back on the top of the door frame? I can't seem to get it to stay
Old Aug 28, 2023 | 06:35 PM
ldrny's Avatar
I got it, thanks all!
Old Aug 28, 2023 | 08:05 PM
Great.
Warrende
Jun 22, 2022 01:15 AM
ncanales33
Dec 27, 2018 05:08 PM
SCmaverick96
Oct 6, 2013 05:06 PM
badboye46
Sep 28, 2011 03:18 PM
