Need some help omease
Old Jul 10, 2018 | 06:57 PM
hqmok's Avatar
Default Need some help please
my 2003 Jaguar S type R is showing bank 1 & 2 lean. I’ve done all o2 sensors, air flow meter, smoke test, and still continue to get this code with restricted performance. Once I get on the freeway within a minute or two, restricted performance goes off and is fine while on the freeway. Once I get off the freeway, eventually restricted performance will come back..... anyone with suggestions, I’m about at my wits end.... thank you.....
Old Jul 10, 2018 | 07:25 PM
NBCat's Avatar
Did you check fuel trims? Are there any DTCs stored? If so, post them here.
Old Jul 10, 2018 | 07:35 PM
hqmok's Avatar
Default thanks for the reply
I did not check fuel trim , I’ll post DTC once it comes in again
Old Jul 10, 2018 | 07:38 PM
hqmok's Avatar
I’ll post codes once they come up again. I just know it’s bank 1 & 2 lean..... any suggestions on checking fuel trim.....? Fuel filter has been replaced....
Old Jul 11, 2018 | 02:39 AM
JagV8's Avatar
OBD tool with live data. Note the trims (LTFTs). Hot engine, parked, at idle.
Then rev ~2500 and note them again.
Jsedita74
19
Dec 8, 2012 09:37 PM
Stav_98
26
Apr 7, 2010 02:32 PM
afonda
Nov 3, 2009 06:58 PM
alwr333
Jul 10, 2009 10:29 PM
soccerstar10
Sep 1, 2007 05:15 PM
