Need your best guess!
Old Feb 28, 2014 | 10:57 AM
devo357's Avatar
Talking Need your best guess!
Ok my wife emailed me some pics today of what looks like alot of oil ALL OVER THE DRIVEWAY! She drove around about 30 miles yesterday no warning lights and she says the engine did not get hot. she parked and smelled oil looked under the car and found this! I will not be back in town until tomorrow so I need your best guess as to where it might be coming from gentlemen. Thought it might kill some time and sharpen some thinking skills.
A little back ground, I changed the oil last sat drove it about 20 miles and seemed fine used K&N filter and Castrol GTX.
Could the filter be loose? (its a little hard to get to with the lines in the way) no known oil leaks and the pan was clean when I changed the oil on sat. I know the drain plug was tight. our drive way slopes down about 20 degrees and the rear of the car is facing down hill.
So this is the oil leak best guess palooza!
Happy Friday everyone
Dean
Attached Thumbnails Need your best guess!-img_8156_zps970f5a16.jpg   Need your best guess!-img_94301_zpsd7b73018.jpg
Old Feb 28, 2014 | 11:11 AM
QuartzSTypeR's Avatar
Is she sure its oil? Maybe the old filter gasket stayed on when you changed the filter and its now double-gasketed. Hard to say for sure its oil and not coolant when it spills on concrete.
Old Feb 28, 2014 | 11:14 AM
joycesjag's Avatar
Could it be condensation from the AC?
Old Feb 28, 2014 | 11:19 AM
devo357's Avatar
Thanks guys, no its oil she put her fingers in the puddle and smelled it to be sure.
Old Feb 28, 2014 | 11:20 AM
devo357's Avatar
Yea I was thinking that too.
Old Feb 28, 2014 | 11:22 AM
devo357's Avatar
the puddle is still there 15 hours later and its definitely oil I even had her go out there with a paper towel to see what color the the fluid was! lol
Old Feb 28, 2014 | 11:36 AM
salmanezkhanz's Avatar
Check the oil dipstick to see if the oil level is low. That should help confirm if it's oil or not.
Old Feb 28, 2014 | 11:47 AM
JagV8's Avatar
Hope it's not trans oil.
Old Feb 28, 2014 | 11:52 AM
devo357's Avatar
What color is the trans fluid Jag?
Old Feb 28, 2014 | 12:55 PM
JagV8's Avatar
Depends how cooked it is.
Old Feb 28, 2014 | 01:06 PM
devo357's Avatar
car has about 52k on the odometer
did complete fluid change a few months ago.
Old Feb 28, 2014 | 01:32 PM
JagV8's Avatar
So what colour was it then and you guess now...
Old Feb 28, 2014 | 01:51 PM
GT42R's Avatar
have her put some absorbent or kitty litter down in the meantime to prevent leaving a stain...
Old Feb 28, 2014 | 02:06 PM
Jon89's Avatar
I agree with either a loose oil filter or the gasket from the old oil filter sticking in place. Always check to make certain the old oil filter's gasket spins off once you remove it. Don't just look at the old filter's base - take a good look at the oil pan where the oil filter screws down onto it. I always wipe that area clean with old newspapers just to make certain that there is nothing left in place to compromise the new gasket's seal before I spin the new oil filter on....
Old Feb 28, 2014 | 07:54 PM
joycesjag's Avatar
Lifeguard 6 ATF is basically the same golden color as new motor oil, FYI.
+10 or whatever the number is CHECK MOTOR OIL DIPSTICK level!
Old Feb 28, 2014 | 09:40 PM
chopr's Avatar
I would tend to agree with the "double" seal on the oil filter diagnosis. Too coincidental with your recent oil change! One other thing, if your car is equipped with an oil cooler, it may be one of those lines. Didn't see which model you had. One thing for sure.... get it fixed before you do some real damage.
Old Mar 1, 2014 | 05:19 AM
cat_as_trophy's Avatar
Default Source of the leak?
Hi Dean,
Presumably, you loosened the sump drain plug to drain old oil ... that you replaced seal on the plug; and checked it was tight and not leaking after refilling with new engine oil?
Don't laugh ... I have a very good mate who refilled the sump without the plug even inserted ... that was a clean up job like no other, with about 6L spreading over my workshop floor.
Cheers,
Ken
Old Mar 1, 2014 | 10:01 AM
devo357's Avatar
I cant check today its pouring rain here in California! but on a paper towel it did look golden and yes I must be the idiot that either didnt check the filter gasket or something related to the oil change. hope it clears up tomorrow i want to get under there and take a look.
Old Mar 4, 2014 | 10:46 AM
devo357's Avatar
Ok guys it was the K&N filter I used it was leaking at the seal, dont know why but that was the problem. I switched it out with a Bosch filter I had from a oil deal from AZ and no more leak! Car was 1 1/2 quarts low.
Funny first time I have had a problem with any oil filter sealing but thanks for the replies.
Old Mar 4, 2014 | 01:18 PM
campaign308's Avatar
My oil filter was loose and leaking as well but not as much as yours ! Had an oil change yesterday !
