New 99 stype owner with a million questions!!
Old Mar 19, 2007 | 04:20 PM
bigdreams05's Avatar
Default RE: New 99 stype owner with a million questions!!
99 S-type? They started production in 00. Also, the 3200 for the S would be a WAYYYYYYYYYYYY TO GOOD TO BE TRUE deal!
Old Mar 20, 2007 | 01:20 PM
Chances of all of your problems being fixed for a mere 300 bucks- It's not Disneyworld. We all agree that the trannys would be fine if they weren't sealed for life. Try to get a tranny fluid change ASAP but that might run you a bit more since I'm sure it's a mission to change the fluid. The knocking on the wheels is a common problem. That's the ball joints needing to be changed. Can you elaborate a little bit more on the knock-out you wrote about?
Old Mar 20, 2007 | 01:32 PM
12RM's Avatar
The S Type model was introduced in October 1998 here in the UK (Glass's guide).
Gearbox - if the battery is low or on it's way out you can get gearbox fault indications. Borrow a known good battery of a suitable spec and of recent vintage and see how it goes with that. The battery will last about 4 years in these cars before you start having problems.
Knocks - could be the anti roll bar and or bushes. Ball joints if badly worn will also knock.
Edit - I had the ATF and filterreplaced for £99 by a reputable transmission rebuilder. Shop around and take some advice.
Old Mar 20, 2007 | 02:41 PM
Kit1's Avatar
£3200. I wouldn't mind spending some cash on these faults it that's all you paid for it. Even if it came to a couple of grand you'd still be quids in.Are you sure it's not a ringer ?
Old Mar 20, 2007 | 03:03 PM
BTW, how many miles?
Old Mar 21, 2007 | 02:00 PM
Probably an engine oil change, spark plugs, air filter, maybe a pollen filter, and if your very lucky they might do brake fluid and powersteering fluid, but I doubt it. Heck, they might even put an air freshener on your rear-view mirror.
Old Mar 21, 2007 | 03:15 PM
Kit1's Avatar
A ringers a car that's been written off and given a new identity after repair or unregistered crash damage repaired then sold on. I'm sure you've checked it out by HPI etc and it's cool. Enjoy. [8D]
Forcedair1
Sep 8, 2025 01:57 PM
H20boy
Dec 24, 2024 03:23 PM
James007
Oct 3, 2015 03:29 PM
jfitzoz
Sep 7, 2015 04:28 AM
carcycle
Sep 7, 2015 04:14 AM
