NEW driveshaft support bearing..
Old May 27, 2015 | 06:29 PM
Razorback31's Avatar
Default NEW driveshaft support bearing..
Over the last few months I've been trying to find an alternate of buying a completely new driveshaft for thousands of dollars.. I got a used to replace old bad one but I think this is going out too . Anyway today I was looking on ebay for a good used ds with bearing.. but I ran into this.. eBay item number: 151686043963 I just ordered one and when I get it I will see if it's correct. (I already bought an ls type bearing with no luck, let's hope this one is legit. Anyone bought one?
Old May 27, 2015 | 10:42 PM
clubairth1's Avatar
Community Influencer
Those don't go out much so we don't know.
What was the car doing when the drive shaft support bearing was bad?
I have never replaced one.
Old May 28, 2015 | 11:00 AM
Very very loud vibration that shakes the whole car under acceleration. It's the only think it could be. I ordered new shocks to make sure it's not misaligning.
Old May 31, 2015 | 09:19 AM
clubairth1's Avatar
If you can let us know how the repair goes.
This may start to show up as the miles build up on our cars.
Old Jun 1, 2015 | 12:15 AM
I will take photos. I've considered getting my driveshaft balanced to make sure that's good before I put it all on.
Old Jun 3, 2015 | 09:10 PM
I got the part tuesday I hope to get some photos and the new bearing installed tomorrow.
Old Jun 4, 2015 | 12:32 PM
tbird6's Avatar
Thanks and I hope it fixes your problem.
I am interested because we don't see any problems in this area. I was expecting the rubber Guibos to give problems as I see on BMW's but so far we don't.
Old Jun 5, 2015 | 10:08 PM
All I have is a photo of the bearing. Looks like to get the old one off yiu need something like a gear puller with small teeth. I hope to get it swapped on tomorrow. I'm starting to hear a bearing squeeze while driving when I accelerate or give throttle so it's convincing me even more that's probably what it is. Gotta do it soon don't want a driveshaft flying through my floor board.
Old Jun 12, 2015 | 11:03 AM
I got the new bearing installed sunday and so far it's eliminated the wobbling. I had to change the flex couplings too and I'll show a photo of why. The couplings were so gone tjat under load it was flexing so much that the bolts/nuts were actually hitting them self on the flange of the other flange. Both the rear and front and rear.
Old Jun 12, 2015 | 12:52 PM
tbird6's Avatar
Did you have to press the center bearing on like you thought?
Any tips on getting it in?
Did you replace both couplings too?
Old Jun 12, 2015 | 08:14 PM
Yes and no.i used used a pipe the same size as the output shaft and tapped it on to the shaft. I had to use a gear puller to pull the old one off after I cut through all the rubber.
Old Mar 12, 2025 | 01:28 PM
jagxfguy's Avatar
did you find out were to get the center support bearing ? I have a Jaguar xf 2011 5.0 and can’t find the piece any were , not trying to buy a whole new drive shaft. I’m reading and ending up here . Any advice on what you did ?
Old Mar 12, 2025 | 01:29 PM
jagxfguy's Avatar
Attachment 113469
does this fit for Jaguar xf 2011 5.0?
Dave1109971
Dec 15, 2015 06:16 PM
RedRider48
Oct 1, 2015 08:18 AM
Vector
US Lower Atlantic
Sep 28, 2015 11:08 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
