New here but need help please
Hello I am a new jaguar owner
I have just purchased a 2004 s type 4.2 V8
6 speed
but are all ready worried I keep getting engine coolant low it does go off some times
but coolant level is fine
also could someone please tell me where do you plug in a scanner
is have owned bmws for 20 years and know them inside out
but jaguars are completely new to me
Thanking you
Darrol
6 speed
Thanking you
Darrol
6 speed
Thanking you
Darrol
6 speed
Thanking you
Darrol
and can fall down a little if not locked in .
located central underneath the coolant tank/reservoir .
the obd2 plug is upwards to one side of the steering column facing down through the lower dash cover trim .
first check the coolant level sensor is correctly fitted , it locks in like a turn to lock light bulb .
thank you so much
If your coolant level is good, then you must be getting a false indication. Details on the sensor can be found in this thread:
https://www.jaguarforums.com/forum/s...lacment-52090/
It primarily covers the V6 models, but also has some info for.your V8.
Try this to rule out a basic thing.
1. Cold engine
2. Loosen the vent screw on the degas bottle. (right next to the coolant fill cap)
3. SLOWLY pour in the proper fluid mix. Let it stabilize for 5 mins and repeat until full.
This is to make sure you've purged out the air.
NOTE: A mistake I repeatedly made was filling too fast. Once I slowed the fill rate and let it equalize for 5 mins at a time... it was properly filled and I no longer had issues. (did this two different times too)
1. Cold engine
sinker123
40
Jun 25, 2018 01:22 PM
cbryantjr85
Oct 21, 2016 03:46 PM
JimC64
Nov 22, 2012 07:26 AM
CarSmartNot
Sep 26, 2009 03:47 AM
