New Owner with a tachometer Question
Old Oct 13, 2014 | 05:41 PM
rfshafer`'s Avatar
Default New Owner with a tachometer Question
Just bought My Wife A 2003 S type 4.2l. 81000 miles It has a problem with the tachometer If i drive nice and easy on the throttle it has no problem its when i push hard on the throttle the tachometer goes crazy it goes all the way up the drops down to zero then after next **** goes all the way up when i say all the way up i mean slams all the way up To me it seems the tach is bad my next question is I f I change my instrument cluster with a used one will i retain my mileage info or will it be from the the one I install I could post a video if needed
Old Oct 13, 2014 | 05:43 PM
JagV8's Avatar
You can get it repaired. Difficult to change as it's part of the security system - don't just fit another!
Old Oct 13, 2014 | 06:10 PM
rfshafer`'s Avatar
Thanks for answering my question that explains why a used instrument cluster is so cheap on E bay they are useless....
Old Oct 13, 2014 | 08:11 PM
Mikey's Avatar
I hate when that happens.
Are you sure it's just the gauge that's going nuts and not actually the engine revving?
Old Oct 13, 2014 | 10:11 PM
salmanezkhanz's Avatar
I had my tachometer replaced under warranty, and the dealer had to reprogram my keys to complete the process. So as JagV8 said, if you're doing it yourself, better to get it repaired than swapping in another one.
Old Oct 14, 2014 | 01:15 AM
JagV8's Avatar
Look on google for "ecu" repairers. Something like BBA-Reman or ASI?
Forcedair1
Sep 8, 2025 01:57 PM
James007
Oct 3, 2015 03:29 PM
teacoff
Sep 10, 2015 08:25 AM
jfitzoz
Sep 7, 2015 04:28 AM
James007
Sep 6, 2015 06:47 PM
