No fan
Old Jul 3, 2015 | 07:57 AM
Markgibson's Avatar
Default No fan
Hi guys and gals
Any help very much appreciated as I know I'm being blind but it's doing my head in!
I have a 2001 2.5 V6 s type and it really enjoys overheating in traffic/stationary!
I have had a good feel of all the hoses and all are hot the radiator seems fine and I'm not loosing any coolant, but....the fan doesn't run...at all! After having a read around it seems the FCM is the most likely culprit. I just can't find the little blighter.
Can anyone enlighten me??
Ta
Mark
Old Jul 5, 2015 | 10:16 PM
abonano's Avatar
Mark,
The FCM should be right behind the radiator lower drivers side but check the fuses and relays before ruling out the FCM.
Definitely sort it out before doing any long term damage to the engine.
Old Jul 5, 2015 | 10:36 PM
NBCat's Avatar
What is the age and condition of the battery? Check common earthing points and fuses as well.
Is the thermostat functioning correctly and does the engine have the proper level of coolant?
Old Aug 7, 2015 | 12:45 PM
roger.grote's Avatar
I had the same trouble and it turned out to be the wiring from the fan had been cut by the chassis.
Old Aug 7, 2015 | 03:01 PM
Markgibson's Avatar
Do you know where the cut was? I haven't been using the car much because of this issue and I want to get back to enjoying it!
Old Aug 8, 2015 | 05:08 AM
I did have it repaired by a local garage but they told me it is where the wiring loom from the fan went across the chassis member.A jaguar garage wanted to charge me for a complete fan assembly but my garage just mended the cut and then protected it from chaffing again,apparently it is quite a common fault,Sorry I cant be more specific hope you find them cut and get back on the road ASAP
Roger
Old Aug 9, 2015 | 05:06 PM
Warspite's Avatar
One thing that I personally ran into: fan would never turn on...because there was bad contact right at the fuse holder. Blades of both the fuse and holder were oxidized. Sprayed both with DeOxit D5, then roughed both with a needle nose plier, to get to bare, clean metal. With a hot engine, it came on immediately. Try this before chasing ghosts or cutting wires. Might be just that simple!
Old Aug 10, 2015 | 04:51 PM
tbird6's Avatar
If you plan to keep the car get the shop manual.
It's free and on this site and called the JTIS. Instructions are at the top of the forum.
Very good information.
Seth
Nov 1, 2015 12:17 PM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
LnrB
Oct 13, 2015 12:45 AM
workworkwork
Oct 1, 2015 01:44 AM
Darrenmb
Sep 27, 2015 08:43 AM
