no hid headlights
Old Oct 17, 2011 | 01:42 PM
tiaaa's Avatar
Default no hid headlights
2003 s type, no headlights hid. what is the votage going to the ballast? I know i will have to take off bumper. checked fuses ok. checked relays and they click when putting back in. I am stumped. Seems strange both sides are out. thank
Old Oct 17, 2011 | 01:55 PM
SchultzLD's Avatar
Switch in the collum? (Forget the correct name, but the thing that fails a lot and is talked about a lot on here... all the buttons for the wheel go through it... figure it out yet? lol That thing) Not sure if the control goes through that or not but regardless check the switch.
Did you see if the voltage changes at the lights yet? BTW, just cause the relay clicks when putting it in, does not mean it is working properly. Just means it IS getting power, but is it sending it? Multi-Meeter will be your friend here.
Both not working means something common is at fault... switch, relay, fues, ground...
Edit: you posting from a phone? If so, Mods, why can't we add Sig's from phone?
Old Oct 17, 2011 | 02:11 PM
tiaaa's Avatar
thanks for the reply. if i get votage to the ballast and turn on and off the headlight switch that i think would tell if the switch is ok i think? do you no the voltage to the ballast?
Old Oct 17, 2011 | 02:22 PM
SchultzLD's Avatar
Not a clue what the voltage should be, but at least it iwll tell you if it's getting power. If they both are, then either both lights are out, or perhaps yuor not getting enough power? Someone more helpfull will chime in I'm sure.
Old Oct 17, 2011 | 03:41 PM
phd12volt's Avatar
if your getting at least 12.6 to the ballast input, then you should be fine with the switch. Did both go out at once??? or did one go out followed by another?
Old Oct 17, 2011 | 08:35 PM
tiaaa's Avatar
phd
bought the car used a week ago. so i dont know. tx
Old Oct 17, 2011 | 10:08 PM
phd12volt's Avatar
2003 JAGUAR S-Type (With HID (high intensity discharge) headlamps)
Low beam headlamp
HID-D2S
Old Oct 17, 2011 | 10:13 PM
phd12volt's Avatar
25 dollars shipped replacement bulbs, cheap easy way to tell if it is the bulbs or not:
http://www.ebay.com/itm/HID-XENON-HE...#ht_6111wt_919
hoodun
Nov 20, 2022 02:35 PM
kingdom worker
Nov 14, 2020 03:47 PM
Fletch44
Sep 28, 2015 02:21 PM
kevinl
Sep 24, 2015 08:25 PM
